Question about HP Photosmart C4180 All-In-One InkJet Printer
Hp c4180 paper went halfway in cant pull out how open the back or get paper out
You CAN open the back, from the left as the flashing picture help shows on the little pop up screen. You just put pressure on the black disk like thing that sticks out, pressure towards the right side, and the back pops off. My husband provided that little extra oomph for this, after I thought I tried everything. Sure enough there was a 4/6 paper stuck back there.
Posted on Nov 08, 2012
    Novelist:
  • 111 Answers
-disconnect the power cord from the back of the printer while it is turned on. -remove the back door and take the paper out from there -do not take the paper out from the front as it may cause damage to the rollers
Posted on May 29, 2011
.comHP C4180 I think I
Unplug the printer from the power and press and hold the power button down for 30 seconds or so. Then turn the printer around so that the back is facing you. Look for two thumb release latches to open the back end view of the rollers. you should be able to open the hatch in the back to get an unobstructed view of the paper rollers. Clear out any paper jambs in this area. Then turn it around with the front facing you and put your fingers in the groove of the plastic panel right above the fold down tray where the paper comes out and pull the hatch downward towards you. This provides a front view of the inside area where the cartridge carriage goes back and forth. Clear and remove any paper or debris in this area. Then plug the printer back in and turn it on, and it should rotate the paper feed forward before winding backward to the starting position. Leave the hatch in the front open or lean downward so you can see the rollers and turn it on and off again to watch and see if anything is stuck on them (like a sticker or label). If you see something stuck there that appears when the rollers roll forward turn the power off to stop it in motion so that you can reach in and remove it before its rotated towards the back.
Jul 06, 2011 | HP Photosmart C4180 All-In-One InkJet...
I was printing a 10-page job and the first page just got stuck halfway out of the printer. I tried pressing the reset buttons, tugging gently on the paper, nothing. I tried unplugging it and plugging it...
If the paper is halfway OUT of the printer, that means that the other half is stuck in the fuser.
Open the toner cartridge door and remove the toner. Leave the door open. This relieves tension on the rollers.
Grab the paper as close as you can to the back of the printer and pull the paper out carefully.
Put the toner back in and close the door. You may have to power cycle the printer.
Feb 02, 2011 | HP LaserJet 1012 Printer
Hi what to do when the paper is jam/stock
Open the rear panel door and pull out the jammed paper or if it isn't there, open the front panel door and check there, if so, just pull it out. It's helpful when you switch on an off the machine while you pull. check out the flash tutorial here..click to open the link
Good luck.
Thanks for using FixYa.
Jun 18, 2010 | HP PhotoSmart C4180 All-in-One Color...
My HP PS C4180 all-in-one paper jam error
Hello there This may work for you, it has worked for many here I given this advice so gave it a try it could work for you Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 27, 2010 | HP Photosmart C4180 All-In-One InkJet...
PAPER JAM WITH NO PAPER
This may be caused by a dirty sensor. Disconnect power supply, open the printer and clean everything. You may use toilet paper. Be careful not to leave fragments of toilet paper inside the printer.
May 05, 2009 | HP PhotoSmart C4180 All-in-One Color...
Paper jam
Open the printer, usually on the back, and check the status of the paper. After remove the paper, use some dust spray to remove the small pieces of paper (if any)
Jan 28, 2009 | HP Photosmart C4180 All-In-One InkJet...
Cannot open rear door
I figured it out! I yanked the tab to the right extremely hard, thereby opening the door. Obviously, "press in the tab" was incorrect in HP's manual.
Sep 18, 2008 | HP PhotoSmart C4180 All-in-One Color...
How to take apart HP C4180 All-in-one
After talking to HP tech support and tring all the textbook fixes for my false paper jam,I think i have found the problem,at least mine works like new again!!!!! Take the left and right side covers off,,,,make sure your unplugged! On the right side off your ink tray is a small box with a lens on the bottom make sure that is clean..... On the left side you see a few large gears,,,on one near the center is a clear disc with numbers on it,,,,,,turn the gear closest to the corner back and forth,,,,clear plastic disc should turn also,,,,if it does not,,,gently turn it with your finger tip,, it should tighten up... Line it up so black sqare is at the bottom,,,,,slide ink tray to center position,,, restart printer,,,good luck
Mar 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP Photosmart C4180 All-In-One InkJet Printer Logo
63 people viewed this question
Seeker5211
Seeker5211
