Question about Nokia 1600 Cellular Phone
Voltage over limit - Nokia 1600 Cellular Phone
On a ceiling fan with a watt limiter .. should I still have approximately 120 volts at the bulbs if watt limiter is working correctly ?? Or does the watt limiter also reduce voltage ?
It depends on how the limiter works. Watts = volts x amps. Reducing either volts or amps will reduce watts. Best way to answer your question is with a voltmeter. Take a reading in a bulb socket when powered on and watt limiter set to maximum watts. Then take a reading with the watt limiter set at 50% [half].
Mar 26, 2016 | Dryers
I have a AEG F88060VIOP dishwasher - showing error coded ,00 and beeping. Not listed in manual - can anyone help id cause and fix please? Thanks
Fault code "i00" means "Low mains voltage"
The electronic board makes sure the dishwasher operates within certain voltage limits. If during a cycle the voltage drops below the lowest limit, the electronic board suspends all loads and interrupts the cycle under way. The "i00" alarm is then triggered. The lowest main voltage threshold is 180 Volt. If the voltage goes back to over 186 Volt, the electronic board cancels the error status and the cycle
resumes. The "i00" alarm is also deleted.
If the mains voltage continues to exceed the maximum threshold, the electronic board does not do anything.
My suggestion is to call your local electrician to check the voltage in your home.
Dado
Feb 23, 2015 | AEG Dishwashers
What does fault code f03 mean in miele g7881 washer?
Wash water
temperature T3 in
wash block CHDESIN
not reached
within 60 minutes
Temperature limiter F2 has
cut out
Reset temperature limiter F2. See
Resetting Temperature Limiter F2
(Thermostat), 030 4.2. If necessary,
replace the temperature limiter. See
Replacing Temperature Limiter F2
(Thermostat), 030 4.3.
Heater elements do not heat
up
Check heater elements. If necessary,
replace a faulty heater element; see
Heater Element Replacement, 030 4.5..
Heater level switch does not
switch
See Heating Level Switch Does Not
Switch On, 050 3.1
Voltage (6VDC) from the
electronic not present. The
heating level switch controls
the heating relay voltage.
Check plug connections.
Check electronic module output voltage;
see 070 Fig. 5, Pos. 9.
Nov 08, 2013 | Washing Machines
I am installinga 4548 inverter. At 4500 watts, it puts out approximately 20 amp per phase. My generater that will feed the charging current for the batteries will put outapproximately 28 amps. Is the...
Let just wait a minute. You have an inverter that is rated at 4500 watts. This spooky. The inverter has a three phase input/three phase output? What is the inverter going to be used for?
Next question. What type of batteries are you using and what is the voltage/current in series or parallel? What will be the total voltage you will producing with the batteries? What is the total current of the batteries.
Another question? What is the voltage of the 28 amps? If it going to dump 28 amps across some batteries that rated at 12 volts and 1400 amp/hrs. For 12 volt batteries with a total of 1400 amps. What you will need approx 14 to 14 1/2 DC and with 28 amps across the batteries for charging these batteries. The batteries will be gone in about 1 hour. Boil all the water out of them. When a battery starts to boil it release water with hydrogen gas (the gas is very explosive and dangerous).
You also don't have a regulation circuit to limit the amount of current depending on the needs of the batteries. Also, you don't have a trickle charger to keep the batteries fully charge when the batteries are idle.
You will also need DC regulated charger that will keep the voltage 2-4 volts above you battery voltage. Without this voltage above the batteries voltage it will not charge those batters. Batteries need to forced to except a charge that why voltage above the source voltage. If you can check the voltage on your car/truck with a 12 volt system. While engine is running the voltage across the battery will be 13.8 to 14.1 volts. Now, the current limiter is the alternator it has a regulator built into it for stabiizing voltage and current went the batteries require more current but it limited by alternator regulator
Now, to get more current out of the alternator the regulator will supply dc voltage to the stator of the alternator generator more current. More dc voltage is supplied by the regulator but the dc voltages is limit to about 24 volts. Another limiting factor is the alternator copper windings diameter---larger diameter more current, small diameter less current. Utilities systems use big mega watts generators. The maxi um dc voltage for these three phase generator would like 500 to 800dc volts for peak to peak output. There is a simpler way of doing this.
You need to rethink everything here. Also, I can help you if you supply the needed information.
I truly wish you luck in your electrical endeavors. GB you. stewbison
Aug 22, 2011 | Refrigerators
Error no :-6006
6006 High voltage circuit problem
Any of the following conditions is handled as a high voltage circuit problem:
  • The charging monitor voltage (HVC_MON) signal was detected to be out of the predetermined limits after passage of the predetermined period of time from power on.
  • The transfer voltage monitor signal (T_MON_V) or the transfer current monitor signal (T_MON_I) was detected to be out of the predetermined limits.
1 Fuser unit. Replace the fuser unit.
♦Has the error been cleared?
(Yes) Replace the fuser unit.
(No) Go to Step 2
2 Main Board Assy. Replace the Main Board Assy.
(Yes) Replace the Main Board Assy.
(No) Go to "3.4.2 Electrical Noise"
Jul 13, 2011 | Epson laser Printer EPL-6200L Laser
Pilot light will not stay on
Try to clean the thermopile, it should be free of dirt/ soot so heat from pilot flame could be sensed better. Thermopiles generate small amount of voltage when heated properly, the voltage it creates is used in energizing gas valve solenoid coils.
Check also if the hi limit is good, small amount of voltage thermopile generates pass through hi limit terminals.
Jun 04, 2011 | Pitco Frialator SG14 Deep Fryer
Got a salf contained unit PGB36C0702E inducer and blower keeps running and have no 24 volts to board i check all in line limits it all looks fine. put in new board,same thing.the board flashing 4...
Make sure you have voltage going into the transformer.
Check the voltage coming out of the transformer. IF you have line voltage but no load voltage, replace the transformer.
If you DO have 24 load V, then look for a blown 3 or 5 amp fuse.
If that is not the problem, jumper out, one by one, individually, each limit and safety switch until you locate the failure. Replace that part.
Feb 05, 2010 | Heating & Cooling
Voltage limits
are you talking about the powersupply? open the case of the computer, the powersupply reads all this information on the side.
Feb 18, 2009 | Dell Inspiron 530 Desktop Computer
Nokia 1600 Cellular Phone Logo
205 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
