Washer all works fine, but machine is over 5 years old. the spin cycle getting louder. no screaching, no hi-pitch, just a louder than normal spin. goes thru cycles properly, but too loud. is there any wearable bearing, or balancing damper, or guides that I have to worry about.?
    President:
  • 842 Answers
I'm afraid so. This is classic main bearing wear. The drum sits on a shaft, just like the front wheel on a car. There are 2 bearings, one each side of the drum housing. Usually the inner bearing water seal fails and the bearings begin to rust, causing it to become noisy. Once the water is that far, its not long until the outer bearing goes. At some time in the process, you will begin to get a water leak from the rear of the drum tht will get progressively worse.
You can change the bearings and I work with professionals who claim that they can have a drum out, bearings swapped and back in within 45 minutes. I've never got it down below an hour and a half on a machine I know well and you will need, if not SPECIAL tools, then a tool of some description to knock out the old bearings that are pressed into the drum. This is a job for the hardened DIY enthusiast and a pig of a job if you've never done it before.
Bearing sets cost (depending on the machine, the supplier and how many you buy) around £25 in the UK (About $40). Calling out a guy to do the job will easily quadruple that cost (He will probably come with a refurbished drum, swap it out and then take yours away to refurbish).
With this information, you now have to ask yourself if it's worth the effort on a machine that may be reaching end of life anyway.
Typically, the noise will get SCARY and the water leak annoying long before the machine actually fails to work. My advice would be take this as notice that your machine is about to go to the scrap yard in the sky and start looking for a replacement before it croaks on you at an inappropriate moment.
Posted on May 27, 2011
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
I have a eterna EWA5600G king size washer that is making a very loud sceaching sound
check the drive belt from the motor to the gearbox it might be louse that would make it screach and week agitating
Dec 01, 2011 | Washing Machines
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Machine making a knocking noise during spin cycle. The drum shaft has alot of free play front to rear and I suspect that is where the problem resides.
If your machine is making louder than normal noise during spin it could be the failure of the basket. Mine is just under three years old and the basket became looser than normal in the tub. I diassembled the machine...a lot of work...and found the aluminum casting around the shaft and bolted to the basket had rotted away. It looks like it was attacked by the bleach since I had my water checked and its pH is fine. It is likely the root of the smell we have experienced with our clothes when they sit too long in the machine. I spoke with GE and they gladly agreed to replace the parts needed but it is a ton of work to install them. I plan to treat the new part with some zinc chromate if I can get some before the parts arrive. See the picture if it attached correctly.
cid:07d1be63-2d47-407a-89ca-6090b4131d58
Nov 16, 2009 | GE WSXH208A Front Load Washer
Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
Maytag Performa Washer
Hi brawn253
The oil is comming from the transmission. The only way to fix it is to have it replaced. alot of the orlder machiens have this happen and keep working for many years after. as for the squeal its normal. its just the break some of the oils have got in there and the squealing is a resault of that. I wouldnt be to worried about it.
brent
Sep 21, 2008 | Maytag Performa PAV2200
Admiral mega 22 plus : knob and spin problems
Rick,
Just call service. Next time you buy a washer or dryer do not shop price! If you have the money to buy a good machine, BUY SPEED QUEEN. IT'S A COMMERCIAL WASHER THAT WILL LAST YOU. THEY CAN DO 8 LOADS A WEEK FOR 25 YEARS.
AND THE BEST WARRANTY IN THE INDUSTRY!
CHECK IT OUT! I'M NOT SELLING YOU ANYTHING. SO DO NOT LISTEN TO THE SALES PITCHES!
Neil
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jun 05, 2008 | Maytag Performa PAV2200
FRIGIDAIRE WASHER , MY CLOTHES COME OUT STILL WET
Same thing happened to me. The belt just went and I think the bearing is going as well. ANyone know if there are any manuals on the breakdown of these machines?
Apr 16, 2008 | Frigidaire GLWS1233A Top Load Washer
Washing machine is louder then normal on the spin cycle.
This sounds like the rear bearing is going. After getting louder, the next problem is grease appearing on your clothes during the spin cycle. This is a very major repair.
Jan 10, 2008 | Kenmore 43042 Front Load Washer
Washer stops after wash cycle
the timer is bad you could try cleaning the points by taking it apart very hard to do though
Aug 27, 2007 | Kenmore 23822 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
