Question about Friedrich D65A Dehumidifier
Light says "bucket full" but
  • Friedrich Master
  • 43,501 Answers
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on May 27, 2011
Dehumidifier manual
Good morning friend, thanks for your post!
Based off what you're explaining it sounds like your Frigidaire dehumidifier might not be leveled. Any time your dehumidifier is not properly leveled water will not drain out the rear but instead into the bucket. I would recommend checking to assure your appliance is leveled. If your dehumidifier is leveled detach the hose to make sure nothing is blocking the water for exiting into the hose. If those steps are unsuccessful and you continue to get water into the bucket please respond back and I can research more information for you. Best of luck. -Matt
Aug 17, 2014 | Dehumidifiers
The "full bucket" light is blinking- and the
When the Bucket Full Light is on, none of the controls (other than the On/Off) will work. If you haven't
emptied the bucket, do so. Then make sure the bucket is reinstalled properly into the holder. Failure to do this will cause the Bucket Full Light to stay ON. While you have the bucket out, check the inside of it for a float valve. It may be stick in the UP position. If so, jiggle the handle to make it return to the DOWN position.
I hope this helped you and thanks for Choosing FixYa.
Aug 12, 2011 | Kenmore 54501 Dehumidifier
Slow blinking light the same as johnworland on june 13th. A solid light indicates full bucket. I was getting full bucket light the last couple of times I checked the unit. odd because it is set up for...
remove the bucket and check the yop of it for a Float Valve. The float my be stuck in the UP position, If so, jiggle the arm of the float to make it return to the DOWN position.
Jul 13, 2011 | Comfort-Aire BHD-301 Dehumidifier
Bucket full light on continually,cannot reposition bucket to make light go off
heatman101
Jun 23, 2011 | Haier HD656E Dehumidifier
Unit will not run as the "bucket full" switch
heatman101
Jun 05, 2011 | Comfort-Aire BHD-501 Dehumidifier
I noticed that the "bucket full" light is on and
heatman101
Mar 31, 2011 | Comfort-Aire BHD-651 Dehumidifier
It stopped working. One display reads "CH" and
heatman101
Mar 26, 2011 | Comfort-Aire BHD-501 Dehumidifier
Hi, I have an LG dehumidifier, model number LHD650EBL. I have a hose attached and inserted directly into a drain in my basement, bypassing the water tray. Problem is, my dehumidifier is saying...
Try to see if operating the float lever by hand can make it turn off the 'bucket full' message. Maybe use a rubber band or tape to keep it in the on position vs. the 'bucket full' off position.
Check to see if the bucket has to be inserted for the unit to operate, and if the bucket has a nozzle to hook a hose up to at the bottom. I have a dehumidifier of a different brand that has this feature that works with the bucket in, but with the drain nozzle on the bucket connected to a plastic tube that leads to a drain for continuous operation without having to empty the bucket.
How is your hose attached to the unit if it isn't attached to the bucket?
Good luck on this repair.
Dec 01, 2010 | LG LHD65EBL Dehumidifier
Friedrich D65A Dehumidifier Logo
309 people viewed this question
Top Friedrich Dehumidifiers Experts
jhnolson
J.D. Browning
J.D. Browning
bobalix
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
