Question about RIM BlackBerry Pearl 8100
Stuck in loop at initial setup - RIM BlackBerry Pearl 8100
    Scholar:
  • 132 Answers
What type of PDA is it ?? PALM / HP . .etc...
Posted on Aug 16, 2008
Can i add more memory to the rc50 loop pedal
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
Apr 14, 2017 | Boss Rc 50
Need to know what key is for safemode. computer is not coming on and is stuck in set up is starting services.
Tapping F8 during the initial boot will get you to the menu to choose Safemode, Last know good Config., etc. All Windows OSes are the same in this respect.
If you are stuck in a setup loop, this probably will not work for you. Windows generally would have to have been completely installed before this would work...
Apr 08, 2011 | Acer Aspire 5551 Notebook
I am stuck in the boot up process with the option
Look at the HDD (Hard Disk Drive) LED light...
Is it a steady red? Put your ear to the computer case. Do you hear a repeating clicking sound?
You should be able to press [F10] to get out of the BIOS Setup. If not, it may be a loose hard drive cable (open up the PC) or a failing Hard drive (replace).
Oct 20, 2009 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
Carried out an update, but now stuck in loop
Procedure for Entering Safe mode when PS3 is caught in update loop:
When you first turn on the PS3, it will not allow you to go into Safe mode. You must prepare it for this.
link for flash drive prep:
http://www.us.playstation.com/Support/SystemUpdates/PS3/pc_update.html#update_PC
(This will not work for the drive that currently is caught in the update loop. You must take the hard drive out of the PS3 and temporarily replace it with another 2.5” SATA drive. Note: temp drive may need to be initialized… Connect drive to pc, right click on My Computer and select Manage… Then select disk Management… you will then be presented with a dialogue box that will assist in initializing the disk.. However, only initialize it… Do Not Format it!(waste of time) Once the disk is initialized disconnect it from external enclosure or shut down computer and remove disk)
From the top:
1.) Plug in PS3 and flip switch in back of PS3 to on. Red LED in front of PS3 should light up. Also, plug in Controller at this point.
2.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then a final beep and the PS3 will power off again and Red LED will be on
3.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then two beeps
4.) As soon as you hear the two beeps, hold PS button on Controller
a. You will then be presented with an options screen
i. Restart System -- leads back to update loop
ii. Restore Default Settings --
iii. Restore File System -- leads back to update loop (8002F14E)
iv. Rebuild Database --
v. Restore PS3 System --
vi. System Update -- will cause error
5.) You will then remove the temporary SATA drive from the PS3 and replace it with the hard drive that is caught in the update loo
6.) I am currently stuck attempting to Restore Default Settings and Im sure it will end in error, but i have to try all possible solutions.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
EliteGroup G31T-M initial boot stops
Remove the CMOS battery for a few hours then place it back in. I bet it sound like the CMOS is stuck in a loop.
Dec 30, 2008 | EliteGroup ECS G31T-M Motherboard - Quad...
Sandisk M230 not working
ok your first wuestion why is it at a initializing loop what hapened is when yuou had it in your computer and it was initializing you or someone else bumed it or droped it and something got nocked loose and your secend answer is if you have not already sone so reinstall your USB drives ~SP1Grim
Dec 10, 2006 | SanDisk Sansa m230 MP3 Player
RIM BlackBerry  Pearl  8100 Logo
51 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
