Question about Kwikset 909 909-15 Satin Nickel Smart Code SmartCode Signature Series Touch
My kwikset keyless lock no longer beeps when I press the keys on the key pad, I've taken out the batter pak and re-enstalled them after about 5 min but still no more beeps....
    New Friend:
I don't see a step 11 or 13 in that link. I'm also not even able to get it beeping when I disconnect the batteries and put them back in.
Posted on Apr 07, 2013
  • 963 Answers
Here is a link to the installation and programming instructions for your lock:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
It is important to pay attention to the details starting in Step 7, battery replacement for the lock to operate properly.
In Step 11 you will notice that it is possible to turn off the beep function with ip switch #3. You may have this function disabled.
Also, please review the Frequently Asked Questions in Section 13 before you begin any other steps; you may find the answer that you need there.
Posted on Jun 03, 2011
How do I change the code on a Kwikset key pad
Here you go....
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
pb1000programbutton
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
Aug 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
My key pad does not respond at all, no beeps and does not lock or unlock door. Thought it was the batteries but I changed them and it still does not work. When I put the new batteries in it did flash...
There is only a one year warranty on the electronics and the maker (Stanley-Black and Decker) will not sell the electronic parts separately. Check the installation manual for a reset procedure - basically the lock might be "forgetting" it's programming. Another possibility is that it's trying to move the bolt and can't. Be sure the bolt moves freely.
If the electronics have failed and it's out of warranty, there are other brands that are key-compatible with Kwikset. Weiser locks can also be keyed to be compatible with Kwikset. You'll still have the same problem if the electronics breaks though. The main difference is that other brands don't move the bolt with battery power, they just enable it to be moved by hand.
Jul 05, 2011 | Weiser Lock Powerbolt 1000 Lock
Cant change code on key pad
Here's the installation instruction link for your lock:
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Jun 30, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Was unable to get the '2 beeps' when attempting to set up keyless entry instructions. What do I do now?? Keys ok but no keyless entry possible,,,
Here's a link to the installation and programming for your lock:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
SEE PAGE 9 (Troubleshooting tips) for your answer about the two beeps.
Here is a link to Customer Support:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Mar 05, 2011 | Kwikset Locks & Locksmithing
After seting code key pad sounds and no lock operation???
Why is my Powerbolt beeping?
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
Good luck--and please provide feedback if this helps!
Jan 09, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
How do i change the code in my kwikset 909 keyless entry
un screw the back cover located on the inside of the door , unscrew the two srewa inside that holds the front key pad , when it is removed you will find is has couled tags inside that are placed on regired key numbers for entry good luck
Nov 29, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
Kwikset smart code touchpad electronic deadbolt
I have the same problem, electronic locking system went dead but still beeps, stuck using keys now...according to the kwikset website though it says "Warranties cover the original residential user of Kwikset Products against defects in material and workmanship as long as the original user occupies the residential premises upon which the product was originally installed." so hopefully they will fix the problem
Oct 12, 2008 | Deadbolt PFK Touchpad Electronic Lockset
Kwikset 909  909-15 Satin Nickel Smart Code SmartCode Signature Series Touch Logo
355 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
