Question about Vacuums
When trying to operate the dvd player it states no read disk when there is a disk in the player
  • 300 Answers
Yes, the DVD player will start with "loading" while it tries to read the disc and figure out what kind of disc it is.
The new-er players will read all sorts of discs, but I have an older one that will only read DVD and MP3 discs.
Any DVD player should be able to load and play an original DVD, but not all will comply if it is a backup copy of your DVD.
If your player refuses to recognize the original DVD, it's time to get rid of it. The cost of repairing it will exceede the cost of a new one.
Posted on May 27, 2011
Philips 707/05 Portable DVD Player charging issue.
Just go out and get a new charger to replace the one with defective wire/plug.
Aug 31, 2017 | Philips Vacuums
After powering on my sony rdr hx-750,the wellcome message stays on for a long time and it tells you CANT USE THIS after switching to dvd mode
You can download the instruction manual for your product at http://pdf.crse.com/manuals/2899893131.pdf Please try following the instructions listed for the use of the DVD mode and see if you are operating it correctly.
Regards, Kat
Aug 19, 2011 | Vacuums
I bought my dvd player from Malaysia but I am using it in Middle East where I am currently residing. Initially, we are able to play all dvds (which we bought original) but suddenly, it kept popping a...
Are you using WMP or any third party players to play the dvds ?
I suggest you to check if the DVD region code is set to one (US) or not. If not, change it to one.
The region can only be changed five times, before its set permanently.
How do I change my DVD region?
DVD movies are encoded for different world regions, and your DVD-ROM drive must be configured for the appropriate region in order to play the DVD.
If you have DVD-decoder software installed on your computer, you can usually change the DVD region setting in the DVD decoder program. Follow the instructions in the program's Help file for changing the DVD region setting.
If you have a software or a hardware DVD decoder installed on your computer, you can use Device Manager to change the DVD region setting in your DVD-ROM configuration:
1. Click Start, right-click My Computer, and then click Properties.
2. On the Hardware tab, click Device Manager.
3. In the list of devices, double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
4. On the DVD Region tab, make the desired changes.
You must be logged on as an administrator or be a member of the Administrators group in order to change the DVD region.
Note that the DVD region for most DVD-ROMs can only be changed up to five times, and the number of changes still available is located on the DVD Region tab. If the tab shows that you can only change the setting one more time (Changes remaining = 1), you won't be able to play DVDs that use a DVD region that is different from your last selection. If you run out of opportunities to change the setting (Changes remaining = 0), contact your DVD-ROM's manufacturer to reset this value.
Also install DVD decoder as an issue with codec or DVD decoder could even cause the issue with DVD region code.
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx (Also applies to Windows 7)
Mar 26, 2011 | Vacuums
Sewing machine problem. . . . . .Hello Rick, My machine is an old Bernina 830. The instructions in your blog make sense and should have fixed my problem, but didn't :-( Question: There are 2 pins that...
Yes, from the information I have on your machine the metal disk you refer to is basically a program disk. It operates like the old self playing pianos did with the holes. You stated that the model number is 830. Is that the model number that is written on the machine?
Jan 17, 2011 | Vacuums
Have LG dvd player. When i insert any dvd it does not hold the dvd and opens immediately, however it does not keep opening when power on. I open the cover to obser the problem, i found that when dvd is...
Dear Friend,
All DVD / optical media player operates on LASER beam. When you insert media ( disc) it will try to "Sence" media by switching on the LASER beam. Beam will be reflected from the media and give information about its type and size.
If there is some dirt ( generally dust) LASER beam will become weak and may not provide enough information to the player so it may not rotate.
What you have to do is switch of the player and unplug it. Clean Lens of the LASER pickup with a swab of fine cotton or use lens cleaner CD.
After some time. Restart the system and you will find working normally.
If there is no result, take the system to good technician.
I hope this is useful to you.
Thank you for visiting FixYa.
Dec 24, 2010 | Vacuums
I set up my ONYX SW2300XS which I recieved as a gift (so no reciept) for the first time today. At first it was working well, I inserted a dvd and it played well. I played with the zoom and the skip...
Solution: Return it back!
I had other problems and decided return it.
At first it looks so good: HDMI, SD...inputs and so on.
But operation completly screwd up.
It is a SHAME !
Ed
Nov 16, 2010 | Vacuums
Operator manual for AWA DVD player.PDVD-196LC
You can download the instruction manual in PDF format by clicking this link
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/.
Hope this helps. Thanks for using FixYa
Aug 29, 2010 | Vacuums
Recovery Tank red float disk rising to top when no water is in recovery tank
When you put the filter back on, you must have put it all of the way to the top. There needs to be about a 1/4 in. gap from the top of the filter to the top of the lid.
Mar 18, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
64 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
