Question about Electrolux Kenmore 3.5 cu. ft. I.E.C. High-Efficiency Front Load Washer / Dryer
My kenmore front load washer model 4810 will not spin or drain
  • Jeremy Warner
    Jeremy Warner Dec 02, 2012
    I have the same problem...after several hours of searching ive decided its the wax motor in the door lock assembly. (believe it or not) while these seem unrelated, it turns out the little wax motor sends a signal telling the spin cycle every things safe to go...AND you can test it...Start a cycle and let it start to fill up...2 minutes should be enough to warm the wax motor into the lock position. Unplug the machine. If you can open the door, the wax motor is bad. You should not be able to open the door at this point even if you unplug the machine. By design. No Joke. Ill be danged.
3 Suggested Answers
  • 117 Answers
SOURCE: Stops at spin cycle
Open the lid to the washer and let it down gently. You should hear a click when the lid closes. If you don't hear it, the lid switch might be faulty and this will prevent the washer from going into spin. Not an expensive repair.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
  • 1531 Answers
SOURCE: Washer is not draining. How do I remove the front
you will need to remove the lid first then remove the screws that hold the control panel in place.then you will need to remove the door boot on the front panel. there will be two screws on the bottom of the panel that will need to be removed as well as the screws on the top of the panel.
Posted on Feb 15, 2011
Testimonial: "Thanks so much, really appreciate the quick response!"
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore model 970c44102 front load will not drain while spinning
sound's like the water pump is going out I got a old washer and it dose the same
Sep 15, 2012 | Kenmore 98702 Stacked Washer/Dryer
KENMORE FRONT LOAD WASHER MODEL # 417.44052400 WILL NOT SPIN. CLOTHES REMAIN SOAKING WET.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2011 | Washing Machines
My model 4`7 kenmore washer does not spin.
heatman101
Aug 13, 2011 | Kenmore 98702 Stacked Washer/Dryer
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
Kenmore washer - model #22912 will not spin. It will fill, rinse, and soak...but it will not spin.Water remains.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 20, 2011 | Kenmore Washing Machines
My model 20632 990 Kenmore Super Capacity clotheswasher wont spin or drain
heatman101
Oct 12, 2010 | Kenmore Washing Machines
I have model # 41447102700. It is not draining.
heatman101
Oct 12, 2010 | Kenmore 44102 Front Load Washer
We have a Kenmore washer machine top loaded model 110.44722401.The washer doesn't spin and doesn't finish all the processes.NOW THE WASHER IS FULL WITH WATER. WHAT WE HAVE TO DO?.........
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | Kenmore Washing Machines
Kenmore Front Loader Washer Doesn't Drain
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
May 25, 2010 | Kenmore Elite 45986 Front Load Washer
Electrolux Kenmore 3.5 cu. ft. I.E.C. High-Efficiency Front Load Washer / Dryer Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
