Question about Phil & Teds E3 Jogger
The back wheels of my pram seem to slant inwards. starting to get really hard to push pram. please help!
  • 419 Answers
This sounds like your axle washers are bent. I would suggest that you get replacement axles and starlocks. You can usually get these on eBay.
Hope this helps.
Posted on May 30, 2011
The left front tire on my F150 slants inward. What could be the problem?
Could be adjustment is out, but it could also be failed ball joints or wheel bearings. Are all the wheel nuts tight? Have it check by a garage.
Jan 31, 2018 | Cars & Trucks
How to loosen stop motion wheel on singer 500 slant-o-matic sewing machine
Remove the screw on the clutch wheel. Carefully pull off the wheel, and check the ring. The tabs should be facing outward. If the tabs are facing inward, turn the ring around. If they are, screw the wheel back on and replace the screw. Sometimes it takes a couple of times to get the tiny screw between the tabs.
Feb 13, 2015 | Singer Sewing Machines
What is the problem when the rear tires on a 96 dodge avenger are slanted inward
Inward at the top?? Need's rear struts. Jack up one side, grab the tire, try to wiggle in a back & forth motion. If it is solid then it's not the wheel bearings.
Nov 04, 2012 | Cars & Trucks
Hit pothole and now tire makes clicking noise and tire slants inward
If you feel that you've hit the hole that hard, you should have the wheel and suspension checked by a professional. The strut or control arm may be bent and in need of replacement, but that's only if you've really hammered it.
May 21, 2012 | 1992 Saturn SL1
My front tires are slanting inward and idk how to fix that.
First, are they slanting inwards at the top, or towards the front?
If your tires are slanting inwards like you are turning the car (the front is facing in more than the back when they should be facing straight forwards ... like it's pigeon-toed) then you have an alignment problem. For this you will have to go to a mechanic who can do alignments and they will straighten it out.
If the tire is slanting inwards towards the top of the tire, there are a few issues that could be the cause ...
1. Jack up your SUV so one of the front tires leaves the ground. Grab the tire and push on the top and then the bottom of the tire (above and below the rim). If the tire moves when you push on it, the tie rods or tie rod ends are probably shot. This is a piece of the steering system, and tends to be one of those parts that every car eventually has problems with. If you do not work on your own vehicle very often I recommend taking it to a mechanic to have these replaced since the steering system is so vital to your safety while driving. If you DO most of the work on your own car, and have a lot of experience with it, you should be able to pick up tie rod ends at any auto parts store. While you are there, I recommend getting a Haynes manual for your vehicle -- it will have exact directions on how to change out the tie rod ends, with pictures and all that goodness. If you ever have future problems with the car that you want to fix, this manual will almost always help you get it fixed.
2. If your tire does not move when you check the tie-rod ends, but the tire is still slanted inwards, take a look at your springs and shocks or struts. If the springs are broken or fully compressed when the car is sitting on the ground, then you have to get the suspension pieces repaired. This I HIGHLY recommend taking to a mechanic, even if you DO know what you are doing most of the time. The springs would need to be compressed using a special tool, and if the procedure is done wrong, the springs can shoot off of the compressors and either kill you or cause MAJOR damage to your stuff -- a friend of mine almost died when one of his spring compressors broke ... the spring ended up bouncing around his garage for about 20 minutes, destroying everything it hit, while he hid under the car. Fortunately he survived with no injury, but his garage and car were both totally destroyed in the process).
3. If the springs are not fully compressed while the Bronco is sitting on a flat surface, then it might be the shocks / struts. The only difference between a chock and a strut is that one is in the center of the spring, the other is located right next to it. Make sure that the rubber pieces on your shock/strut are in good condition, and that there is no fluid leakage. If these are broken, I recommend taking your bronco to a mechanic, because as above, these are very dangerous parts to replace if you don't know exactly what you are doing.
The only other issue that I can think of off the top of my head that would cause your tires to slant inwards is loose lug nuts ... but if it is happening on both front tires this is VERY unlikely. Make sure all of your lug nuts are tight or your tires might fall off while driving.
If you have recently swapped out the engine in your bronco for something much bigger, then you might have put more weight on the front suspension that needs to be accounted for ... and none of the above solutions will fix it. For this, you need to upgrade your front suspension to account for the extra weight -- this would require a specialty store, and after-market parts (like a lift kit).
There is also a VERY small chance that you have 2 bent axles ... but if both front tires are slanting in at about the same angle, 99.999% chance that this is not your problem. If it is just one tire that has this problem, then you will probably notice a strange bounce while driving, and this is a more likely scenario ... but I really don't think it's that.
If none of these solutions work ... please put a bit more info about your issue and I will see if I can help some more. If you were able to include a picture of the vehicle that shows how the tires look, that would be a great help. Best of luck .. and be safe if you do the work yourself.
May 24, 2011 | 1991 Ford Bronco
Difficulty unfolding phil and ted stroller
I find that the best way to do this is the following;
Make sure that nobody is standing behind the pram (expecially small people!)
Make sure that the seat unit is raised.
Stand to one side of the pram, bend down and with both small black plastic buttons, push inwards (so that they are going toward eachother)
The back of the pram should fall to the floor.
Where the childs back of the knees are, lift up the fabric a little and grab the black metal bar, then lift this up and the pram should collapse nicely. You should have a ******** the handle bar with a popper on to secure this shut.
I hope this helps.
Aug 13, 2009 | Phil & Teds Explorer V2 Twin Stroller
Back wheels slant inward while in pack
your castor and camber are off go to the local auto shop and they should be able to help you
Jul 22, 2008 | Mercury Grand Marquis Cars & Trucks
Valco pram repair
Hi there.
If it is a plastic moulding that has stuck, use a silicone spray (mr sheen will do) to release it.
If this will not help at all, try your nearest Halfords bike department or bicycle repair shop. I doubt they will charge you anything.
If it is a broken part, find the manufacturer for ordering a replacement.
Hope this helps,
Jun 11, 2008 | Valco Baby Gear
Silver cross 3d pram system in jet sport
i have a silver cross travel system and can only seem to fit the rain cover on properly when its in pram mode how do you do it when the car seat is attached
May 01, 2008 | Silver Cross 3D Stroller
WHEELS!!!
you have to replace the spring inside the wheel hub. the same thing was happening to me and my husband made a new spring out of spring steel. I guess they just loose their strength after a while. It was very frustrating!
Dec 12, 2006 | Bertini 906T TWIN - Navy Check Standard...
Phil & Teds E3 Jogger Logo
176 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
