Question about Sears Garden
My lawn mower starts then immediately stops. As if I let go of the handle to purposely stop it. Help
    Novelist:
    Champion:
  • 222 Answers
I'm guessing you're using a priming bulb to get it started. When you do, you're forcing gas into the carburetor to get it started. Your problem is that the gas is not "flowing freely" into the carb on its own. This is the problem with almost every mower I work on. The carb needs to be removed and thoroughly cleaned top to bottom, which is better left to a professional, unless you are familiar with them. There are tiny parts and very tiny holes in there (called jets) and when gas is left sitting in them for a time, they get plugged up. Most of the time, once you get the carb cleaned up the thing will run just fine. It could probably use a complete tune-up, but since it does start, I'm betting on a dirty carburetor, as the primary issue. Good Luck.
James
Posted on May 27, 2011
How to start it
      Stand behind the lawn mower. Use one hand to hold the engine stop lever in the operating position. Use the other hand to hold the recoil starter handle. Slowly pull the recoil starter handle until resistance is felt, then pull quickly to start the push mower engine.
      How to Start a Lawn Mower ' Starting Snapper Mowers FAQ
      www.snapper.com/us/en/support/.../how-do-i-start-my-snapper-lawn-mowe...
    Feedback
    How to start the lawnmower - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=QsRwZZwO4oc
    May 25, 2012 - Uploaded by iScaper1
    Tips on how to start a lawnmower. I asked my wife and boys today if they could start the lawnmower. One son ...
    How to Start a Push Lawn Mower: 7 Steps (with Pictures ...
    www.wikihow.com > ... > Lawn Care
    wikiHow... there's more to it than that, especially if you want it to keep running. Of course, how to start your individual lawn mower may vary according to what brand and...
Jan 12, 2016 | Garden
Why does my lawn mower start when i use the plunger primer then stop immediately
Sounds like a damaged diaphram. Just happen or first start after sitting for a while?
Aug 31, 2014 | Garden
Why does my lawn mower start and immediately cut off? Installed new plug and filter.
How long has petrol been in mower for. Could have fuel that has gone bad in it. Also when you start mower you usually need to start with the choke activated until the engine gets warm and then take off the choke. Also check the throttle linkage as some mowers have a device that kills the engine when the throttle is pulled down to stop and it is usually on the mower engine and gets activated when you pull the throttle cable to the stop setting. Had one where this was bent. Another thing I have had is a pin that is in the drive shaft that had broken thus causing the mower shaft not to turn with the engine.
Aug 29, 2014 | Garden
What is the purpose of the shroud hole covers on mowers
Apparently stops dirt from getting in there .mbut I couldn't get then in...
Apr 05, 2013 | Black & Decker Black Decker 18 In Mulching...
My self propell lawn mower stop propell
the cable needs tension to engage the belt tensioner
Sep 23, 2012 | Garden
I bought a brand new Troy-bilt lawn mower model 336077 and tried to start it by pulling on the started string after filling gas and oil. But the cord is stuck and the mower does not start. WHat coul be the...
Are you holding the emergency stop lever? If you were operating the mower with your hands on the handle, there is a separate lever that you are expected to hold together with the main handle. You have to hold these two handles together to start and to operate the mower. Good luck.
May 31, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Have never used the lawnmower and the pull cord seems locked or stuck. I can't pull it at all. Is there a button or lever that needs to be pushed before intial use of machine?
There is a brake lever that stops the motor and blade when it is released. This is usually parallel to the handle and would normally be squeezed against the handle when you operate the mower. When released, it is a safety mechanism to immediately stop the spinning blade. You have to squeeze that lever in order to start or run the mower. You can see that lever in the image at the top of your question. Good luck, Al K
May 22, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Zero turn cub cadet Zero Force 50" cut stopped running while mowi
I have an idea. Try to start it again. It should start right up. When it dies again, immediately crack the fuel filler cap, and listen for a vacuum. If you detect a vacuum, clean the cap well, and pay particular attention to the vent hole on the cap. If it is plugged, it will do just what you were seeing.
Hope that this helps!.
Best Regards,
--W/D--
Aug 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I have a black & decker lawnhog mm875 lawn mower that just stopped working. the power to the mower is good. can you help
I had the same problem. Its the switch.
When you pull the plastic handle up, it pushes down a button switch located in the handle. Over time (and with use) the parts begin to wear and the handle is no longer aligned properly with the button. So, ........ when you pull the handke up the button is not pushed in far enough to start the mower.
I want to bypass the handle and hard wire the mower but I can't find a wiring diagram.
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
309 people viewed this question
Top Sears Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dennis Key
Dennis Key
Are you a Sears Garden Expert? Answer questions, earn points and help others
