Question about D-Link AirPlus DI-524 Wireless Router
When i use my router, it doesnt work, it's WLAN and STATUS indicator lamps don't light on, indicating that it doesn't function. how can i fix it? thanks.
  • 61 Answers
I would suggest first unplugging the router and plugging it back in. If you have done this already and it does not work, I would suggest checking the cables in the back. If they are plugged in and you can get online with the modem plugged directly into the computer, then I suggest checking the settings by opening up your web browser and typing in the address bar "192.168.0.1" without the quotes. Put in "admin" for the username and leave the password blank. You should check your settings in here. If you don't know what to look for, find a paperclip or pin and press the reset button in the back of the router. This will set the router back to when it you bought it. You will have to go into that administration page mentioned before and configure your security and other settings you desire.
Posted on May 27, 2011
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
INET light is on not able to connect to internet
Checked the instruction manual online. There's no INET light indicated. There's Power, Status, WAN, WLAN, and LAN LEDs. The WAN LED only indicates that the WAN port is connected to another device, e.g., cable or DSL modem. Check on your cable or DSL modem to see if the Internet light is on. If so, then you'll need to log into your router and go through the configuration/setup per the manual for your type of connection.
Oct 18, 2013 | D-Link 802.11g Wireless Router WBR-1310...
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
Makita HR3000c green light comes when trigger depressed but doesnt work
From the owner's manual: Indicator lamp The green power-ON indicator lamp lights up when the tool is switched ON. If the indicator lamp is lit but the tool does not start, the carbon brushes may be worn out, or the electric circuit or the motor may be defective. If the indicator lamp does not light up and the tool does not start, the ON/OFF switch or the mains cord may be defective.
The easiest to check is the brushes. Most newer tools have brushes with a spring loaded pin in them so when they wear down the pin pops and stops the motor so you don't wear the armature. Even without the pin the wire from the contact to the brush is short so the spring doesn't contact and ruin the armature. If the brushes are OK, you'll have to check the switch for continuity.
Aug 24, 2012 | Makita Drills
Have 1997 heritage softail classic neutral light will not come on even when changing blubs, other lights seem to still work,oil. bright lights, turn signals. Don,t know whar else to do?
Your neutral indicator switch may be bad. Look on the chrome cover on top of the transmission and you'll see a wire that plugs onto the neutral switch. Disconnect this wire and ground it to the engine. Turn on the ignition switch and the indicator light should light up. If it does, replace the neutral switch. If it doesn't, you've got a wiring problem between there and the indicator lamp.
Good Luck
Steve
May 31, 2011 | Harley Davidson FLSTC - FLSTCI Heritage...
Can you tell me if all of the four numbers should be lit up to reflect the Netgear WGR614 is working? My internet connection suddenly quit and I just noticed that on the number "1" is lit.
On a router, the numbers light up only if there is an active computer plugged in to that port. One computer plugged into port 1 the number 1 wil light, and same with 2, 3, 4. No device plugged in to port = no light. Different color lights with different data rates.
Nov 05, 2009 | NetGear WGR614 Router
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
D-Link AirPlus DI-524 Wireless Router Logo
341 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
