Question about Koss CDR200 2-Disc CD Recorder
What type of CD must you use to record on the KOSS CDR200? Is there a specific type of CD that you need to use?
    Brigadier General:
  • 8,546 Answers
A recordable one that says audio or music right on it.
Posted on May 27, 2011
I am unable to engage the record button, the display reads "unreadable or unrecordable disc"
There are several types of blank discs (CD-R, CD-RW). This unit only handles the CD-R discs. Unfortunately, this particular unit is even fussy about the CD-R discs it does accept. Even more unfortunately, there is no way to determine which will be accepted and which will not work. At this point, I can only advise you to try CD-R discs from a different manufacturer. Read the first review on amazon.com. Same issue I have had. Sorry and good luck.
Jul 24, 2011 | Koss CDR200 2-Disc CD Recorder
I have this 2-Disc CD Recorder but I don't have the manual on how to hook it up to my recevier. I'm not sure if I'm to hook it up to the Analog or to the Coaxial Digital. I did try to hook it...
No problem,You need to connect "CD" to" Receiver" in a regular way just to play ..
(output of CD-TO- input of Receiver) ..use either "RCA analog (red/white ) " or "optic " cable.(any standard optical cable )...optic is the best way to connect it..Remember your CD's "OUT" goes into" IN "
pls also remember,wherever you connect your CD on your Receiver,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Koss CDR200 2-Disc CD Recorder
Can I record from a cassette player to the koss
should be able to go directly from tape out of cass deck to input of your koss, as long it has line level inputs (which it should). from there its play on the tape and record on the cd rcrdr. seems the simplest solution
Jan 30, 2010 | Koss CDR200 2-Disc CD Recorder
KOSS CDR 200 RECORDING
Yes, but you, like I could use an owners manual for this thing, as it isn't as easy to operate as the Philips Audio CD recorders. Owner's manual anyone?
You can just press input select for analog, press record, wait then press 'play' to start recording.
Aug 04, 2009 | Koss CDR200 2-Disc CD Recorder
Recording
Willthe b deck playback a normal cd? Sounds like your record laser is gone. It's a philips laser and they are known for it.
Jan 23, 2008 | Koss CDR200 2-Disc CD Recorder
Cdr200 recording
Your CD recorder has 2 sets of phono (rca) sockets on the back. You probably have the outputs connected to your amplifier & speakers. All you need to do is connect your tape deck (or any source except for a turntable) to the inputs sockets on the back of the CD deck.
You might need to switch to external or analogue recording on the recorder.
If you are going to be doing a lot of this type of recording & want it set up more permanently, it might make sense to reconfigure your hi-fi. Shout if you want help with this!
Jan 09, 2008 | Koss CDR200 2-Disc CD Recorder
KOSS CDR200
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
Nov 25, 2007 | Koss CDR200 2-Disc CD Recorder
Koss cdr200 dual burner
I had an issue similar to this - I found if I didn't try to record from the internal player it worked ok. Does it say 'recover' when you try to record anytime? If you open the unit,you might see some capacitors on the power supply on the left hand side have leakedand the power is cutting in and out. 'Recover' usually comes up when a recording is interupted if you switch the unit off during recording.
Aug 28, 2007 | Koss CDR200 2-Disc CD Recorder
Koss CDR200 2-Disc CD Recorder Logo
157 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
