I cant remove the picture that i grab from internet to my disctop and the picture become wall paper
  • mic_nunz May 27, 2011
    i already try it but itstell in there
    Master:
  • 328 Answers
right click on your desk top background --- select properties ---- select desktop from upper tab on box just appeared ---- select desktop - move the slide up and down select you old one
Posted on May 27, 2011
Select the picture with your mouse >> Click SHIFT+DEL
  • 2,418 Answers
Not sure if you want to make a picture your back ground or get rid of one. But here is what to do. Right click any where on the desk top and chose properties chose change desk top back ground and find a new picture you want to make your background.
My paper shredder will not shred or grab the paper?
If the motor is spinning, it's probable broken teeth on the drive gear. The drive gears are usually the first thing to break on a shredder.
If the motor doesn't spin. The paper may be clogged in the grinder claws. You may have to turn the shredder over (after you remove the power cable from the wall outlet). Then remove the papers from underneath.
Hope this helps.
Feb 28, 2015 | Shredder Office Equipment & Supplies
Paper jammed
Lift up the upper section of the printer (just like you were going to replace an ink cartridge) and look for the smallest torn piece of paper hiding in the gears. Then tip up and gently remove the top (black) paper tray assembly and remove any paper in the tray. Grab a flash light and check the "in" feed area.
Put it all back together and hit "start copy". If noting still clears the jam unplug the printer (power cord) from the wall, wait 30 seconds and plug it back in.
Hopefully that clears the paper Jam message.
If not call HP Support Center @ 1-866-408-5408. They're available 24/7.
Jul 25, 2012 | HP Officejet 6500 AllInOne InkJet Printer
Will not grab paper. says out of paper when its not
You can try cleaning the rubber wheels with alcohol. Sometimes they become covered in dust and won't grab the paper.
Apr 08, 2012 | HP OfficeJet 7410 All-In-One InkJet...
I cant get it to grab the paper...have tried everything
Try cleaning the paper pick-up mechanisms with isopropil alcohol, Clean all the paper feed wheels in the paper path as well. These become polished and smooth with time and do not grip the paper as they should.
Feb 11, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Paper not feeding properly, sometimes it goes through crooked and sometimes it isn't grabbed and put through printer
The little wheels that 'grab' the paper sometimes become too smooth and will simply slip on paper. There is wheel rejuvenator you might find at a local stationary store or you might want to try an alcohol soaked q-tip on the wheels.
Dec 02, 2009 | Canon PIXMA iP90v Printer
Msg is paper jam when there is no paper jam
I had what seems to be a similar problem and the issue was that the rubber "feet" that grab the paper weren't grabbing anymore. So, I constantly got a paper jam reading. I read elsewhere to wipe some glass cleaner/ammonia on the "feet" so that they become "sticky" again. When I did this, the "Feet" or rubber semi-circle parts that rotate around a metal bar then started to correctly grab the paper again and the error stopped.
Aug 31, 2009 | Konica Minolta magicolor 2300DL Laser...
Won't grab paper.
Take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer.........
Good Luck
Mar 04, 2009 | Canon PIXMA MP160 All-In-One Printer
Jammed Paper - Canon PC860
You are almont there .There is also 2 clips that release the presure on the sides of the fuser to release the presure on the roller and remove the paper.
Jan 23, 2009 | Canon PC-860 Black and White Copier
Lexmark Z52 won't feed paper
You can try to clean it by using a blower maybe there are some debris stuck on the paper feeder assembly. But if its evident that the rubber of the paper feeder is worn out already then probably needs a replacement. but this parts are sold as one assembly it might cost you a lot.
May 23, 2017 | Lexmark Color JetPrinter Z52 InkJet
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
