Question about Honeywell Programmable Thermostat Heater
Just installed a new visionpro 8000 to run braemar TH3-20 gas ducted heating unit, and it won't turn off it just keeps heating even when switched to off
  • 710 Answers
Hi niklok,
You have the thermostat hooked up incorrectly. Honeywell's directions are sometimes confusing. You should have power first to the thermostat and from the thermostat to the heater. You cannot have power running both to the thermostat AND the heater. That effectively assures a continuous ON situation. The black wire from the panel should be connected only to one lead from the thermostat.
If you need further instructions, please reply back with the number and color of wires coming from the panelboard and the number of heaters and the number and color of wires coming from your thermostat.
Thanks,
Handie Andie
Posted on May 27, 2011
  • Handie Andie
    Handie Andie May 27, 2011
    sorry, not how many heaters. I assume you are using one therm and one central heating unit, correct?
    I am not familiar with Braemer. Need to know what wires go to the heating unit. And if you are using a single pole or double pole breaker.
    Thanks,
    Andie
Honeywell TH8320R1003 VisionPro 8000 not turning on AC
pull the screen off to expose wires. turn power off and put green and yellow with the red. this should bring on indoor fan and outdoor unit when power applied. turn off again and put green and white with the red. this will bring on heat when power applied. if both test work, your tstat is bad. let us know.
Oct 12, 2017 | Honeywell Heating & Cooling
My gas furnace and heat pump runs at the same time???
its likely the outside control unit board its supposed to only kick on gas only when the temp is at freezing..
or
the inside thermostat is not selected for heat pump, open it an look at the jumper / switch.
or just replace the thermostat , then return it saying you couldnt figure it out. :P
there are a lot more variables here after that you cant know how to check.
Nov 05, 2014 | Honeywell VisionPRO 8000 Programmable...
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
Dual heat system, honeywell thermostat, auxiliary heat won't turn on
IT SOUNDS TO ME LIKE EITHER YOUR SYSTEMS LOW VOLTAGE WIRING IS INCORRECT, MOST LIKELY @ THE FURNACE. IT COULD ALSO SIMPLY BE THAT WHEN THE TECHNICIAN THAT INSTALLED THE T-STAT AT START-UP DID NOT GO THROUGH THE INSTALLER SET-UP & CHOOSE THE CORRECT SETTINGS FOR A DUEL FUEL SYSTEM. TRY THIS " SET THE THERMOSTAT TO EMERGENCY HEAT, WAIT A MINUTE OR TWO & SEE IF THAT TURNED GAS FURNACE ON. IF SO THEN IT'S A SIMPLE FIX IN THE WIRING OR PROGRAMMING & NOT SOMETHING MAJOR! GOOD LUCK!
Nov 25, 2012 | Honeywell VisionPRO Thermostat TH8110
Unable to get Braemar Spectrolink thermostate to switch to auto
I have exactly the same problem, did you ever get an answer to this issue?
Sep 08, 2009 | Honeywell Programmable Thermostat Heater
Braemar ducted heating wont switch on
If a used unit check under lid for a pressure hose no thicker than a pen , black or clear, look for splits or if disconnected reconnect
Jul 12, 2009 | Heating & Cooling
Honeywell VisionPro 8000 cycles between Hot and Cold all day.
yes it sound like either they wired it wrong or when theywent and configured the settings this obe did not take to the configuration correctly. Have the contractor come back and do the job correctly or replace the thermostat. Thinks for using Fixya
Dec 24, 2008 | Heating & Cooling
Heating & Cooling Logo
83 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
