Question about Compaq Computers & Internet
My compaq desktop computer wont start up it keeps saying NTLDR missing
  • 1,800 Answers
Hi i have made lil resaerch for this problem so every user who suffurs from this problem can Fixt it on Fixya.com i wish this well helps everyone when u finish rate me plz cuz that was a day and half reasaerch took me a serious hard time but t(his is what i ve got for u Follow me :^^ Issue: NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
Solutions:
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows XP users
Insert the Windows XP bootable CD into the computer.
  1. When prompted to press any key to boot from the CD, press any key.
  2. Once in the Windows XP setup menu press the "R" key to repair Windows.
  3. Log into your Windows installation by pressing the "1" key and pressing enter.
  4. You will then be prompted for your administrator password, enter that password.
  5. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  6. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
If you are attempting to add a new hard disk drive to the computer make sure that drive is a blank drive. Adding a new hard disk drive to a computer that already has Windows installed on it may cause the NTLDR error to occur.
If you are unsure if the new drive is blank or not try booting from a bootable diskette and format the new hard disk drive.
It's possible your computer's hard disk drive may have a corrupt boot sector and/or master boot record. These can be repaired through the Microsoft Windows Recovery console by running the fixboot and fixmbr commands.
Additional information and help in getting into the Microsoft Windows Recovery console can be found on document CH000627.
If you have tried each of the above recommendations that apply to your situation and you continue to experience this issue it is possible you may have a seriously corrupted version of Microsoft Windows. Therefore we would recommend you reinstall Microsoft Windows 2000 and Windows XP.
If you are encountering this issue during your setup you may wish to completely erase your computer hard disk drive and all of its existing data and then install Microsoft Windows 2000 / Windows XP. Additional information about erasing the computer and starting over can be found on document CH000186.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Posted on Aug 16, 2008
  • 185 Answers
One of the file NTLDR is deleted or corrupted on ur OS,so u must re-install the OS again to stop viewing this error msg.
    Sergeant:
    Champion:
  • 214 Answers
You have to repair the operating system or re-install it
Start up problem
You can probably avoid having to reformat your computer. Do you have access to a spare computer? We'll probably need this as we do the repair. Here are the steps: http://tinyempire.com/notes/ntldrismissing.htm
I can provide assistance as we work through them.
Mar 10, 2014 | HP Compaq Presario SR2023WM PC Desktop
Ntldr missing
If you press F11 as you power up, it should find the restore partition.
I would place an OS disc of the same type installed on your laptop and run repair system.
Jan 28, 2014 | HP Hewlett Packard Compaq 6710b Notebook...
Compaq sr1500nx reads NTLDR is missing
boot from your install disk and open CMD, from there use /bootsectit will give you your options
May 03, 2012 | HP Compaq Compaq SR5502FH-E Presario...
I am working on a friends Gateway GT5240E that was running slow for a while so they instead did a system restore & the computer stalled into NTLDR is missing so then now the computer fan will rev but...
Hi
If "NTLDR is missing" massage come its mean your windows loader file is corrupt, that way your windows is not load so install the new windows in your com or repair the windows,,
further help u have to send me friends request lovem84_prashant@yahoo.com
May 06, 2011 | Computers & Internet
COMPUTER GOES ON BUT i GET ntldr IS MISSING WITH A BLACK SCREENI
NTLDR MISSING IS ERROR THAT TELLING YOU THAT WINDOWS CORRUPT- SO YOU NEED TO FORMST THE SYSTEM
May 11, 2010 | Compaq Computers & Internet
Ntldr missing
Thats the boot loader, youll have to do a system recovery using a disc that came with the computer. if you dont have a disc then u may be able to download a iso disk image from the gateway site.
Jan 20, 2010 | Gateway GT5220 PC Desktop
NTLDR is missing
problem:nt device loader error message
Solution: Reinstall windows
Aug 02, 2009 | Compaq Evo D500 PC Desktop
NTLDR is missing. Press CTRL-ALT-DEL to restart
NTLDR MISSING PRESS CTRL+ALT+DEL TO SESTART. WEN I DO THEN WINDOW WITH ALL THE SET UP COMES. PLEASE HELP!!1
Apr 24, 2008 | Compaq Evo D500 PC Desktop
Compaq Computer/Will not Boot up
your nt loader is missing or is corrupt and so u need to format the computer or repair it using windows xp boot cd.
Feb 28, 2008 | Compaq Evo D500 PC Desktop
Computers & Internet Logo
317 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
