Question about Mitsubishi WD-73827 73" HDTV DLP TV
White dots on the right side of the screen - Mitsubishi WD-73827 73" HDTV DLP TV
    Sergeant:
  • 207 Answers
These are called dead pixels if your television is under warranty you should replace it with new one cause dead pixels generated new ones until it will fill up your screen completely.
Posted on May 27, 2011
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Mar 07, 2013 | Televison & Video
How do I open the battery door?
With the display screen facing you, look on the bottom right for the door for the batteries. There's a tiny grey slide switch on the right side of that door with polk-a-dots that you have to slide toward the screen side of the camera. Hold the camera upside down and while sliding this switch away from you, you can slide the door to the right, which opens the battery compartment.
Jan 19, 2013 | Nikon Coolpix S30 Digital Camera White
I have small whitr dots on my picture screen
I went through the same problem with mine started out as one ended with many Its the optical lamp board cost is $600 and some dollars for a model 73-733
Dec 06, 2011 | Mitsubishi WD-73733 73" HDTV
White "press dot" screen
The actual answer is to press the dots, but use a dull plastic tool that fits "within" the dot. Otherwise the width of your finger is too imprecise to calibrate the dots and screen.
Hope you, and others, get this and try it. It works. I just discovered it and did it, successfully after only about 10 presses.
Jul 21, 2010 | Garmin Nuvi 660 GPS Receiver
White dot on my samsung DLP 42" screen
white dot is from a failure in the dlp chip. it controls 1000s of tiny mirrors which help make up your pix, when the mirrors get stuck a white dot appears. over time more will pop up. Probably in the $300-$500 range to have someone repair.
Jul 04, 2010 | Samsung Televison & Video
On the screen of my phone half of it is white with this big black dot to the side of it and i dont know what i should do?
Hi,what makes the phone to display phone half of it is white with this big black dot to the side of it,is because there is a flex inside that connected to the screen of the phone that makes the phone display is faulty and it needs to be replaced so that the screen can be as one again.
Take care.
Jun 23, 2010 | Motorola Mobility Rival A455 Cell Phone
White dots all over the screen
call samsung. there are aware of this issue with several of their dlp sets. To avoid a class action lawsuit, they've extended the warranty of several models to cover the very issue. give samsung a call and see if you model is covered. i just got my 46" repaired at no cost and without a warranty.
Apr 11, 2010 | Samsung HLS4676S Television
White dots in the screen of my Samsung DLP HLT-5075S
This problem cause by DMD chip has been defective. This chip consist of over 2 mil mirrors tiltling to make picture. Some of the mirror does not function causing white dots. If you are in Cali, Orange, Sandiego or near by. Email me at: vinhson65@hotmail.com so I can come and help you. This replacement need skilled technician to relace as it was inside the DMD board.
Aug 14, 2009 | Samsung HLT-5075S Television
Blank White Screen with Black Dot
you can have the phone reflash to correct this problem or just take it into your provider and have them look at it for you.
Dec 12, 2008 | LG RUMOR Cellular Phone
Mitsubishi WD-73827 73" HDTV DLP TV Logo
511 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
