If you are electrically inclined, you can replace the cable jack on the TV ... but it will require some doing. You will have to open up the TV and find the circuit board with teh coax jack on it. take a soldering iron and remove the coaxial jack from the circuit board. Make sure you don't overheat the circuit board while you are doing this, or you will burn out the whole board. Once the jack has been removed, take it to Radio Shack, or a similar store, and find the exact same part. Then reverse the process -- attach the jack without overheating the circuit board, and put the TV back together. ****If you are not VERY good with electronics, don't try this unless you are not afraid of losing the TV -- it is VERY easy to burn out a circuit board.
If there is a TV repair person in your area, it would be a good bet that they can fix it for you at a reasonable price -- just be sure to tell them that all you need is to have the coaxial jack replaced. This way they can only do what you are asking for, and can't charge you for repairs you did not need.
