Question about ECHO, Inc. PB-251C Handheld Blower
Hello, what is the gap for the pick up coil and flyweel for Echo leaf blower PB251.
  • 577 Answers
A bussiness card thickness, slide it between flywheel and coil, the rotate till magnets catches coil the tighten up
Posted on May 27, 2011
How can I test ignition coil?
You connect the negative side to the negative side of a battery, you connect a wire to the positive side of a battery and hold it on the positive side of the coil. When you RELEASE the wire, you get a spark.
Make sure you check whether the voltage on the coil is 6 volt or 12 volt or something strange in-between.
Mar 09, 2016 | Echo Ing Coil Fits Pb251 Pb255 Pb265...
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
What happens if you use 40:1 fuel to oil mix in a 50:1 echo pb251 leaf blower engine?
it is always better to use to much oil than not enough, using not enough will cause major damage to the engine. The oil in the gas mix is what lubes the cylinder/rings against the cylinder walls. 40:1 is way lean of oil for a 50:1 mix engine
Aug 12, 2014 | Garden
Where is the flywheel located on an Echo PB251 gas leaf blower?
Before you go through the trouble of dismantling the blower to get to the flywheel you should perform a compression test. 140 psi is ideal. Less than 100 its probably not worth repairing. Less than 90 it shouldn't run.
Jul 13, 2014 | ECHO, Inc. PB-251C Handheld Blower
Where does ignition coil fit in reference to the flywheel?
Not sure what model you have but for the pb251 echo the gap is:
.012 to .016. Hope this helps.
Jun 18, 2014 | Echo Garden
Need the air gap between the ignition coil and the flywheel for an Echo PB-251 leaf blower
All magnetos work best with minimal air gap. Gap it with the thinnest piece of paper/plastic that you can remove from the gap. Spin it, examine flywheel for evidence of rubbing. If it's good, start it and zoom it a couple of times, shut it down and check again.
lp
Feb 05, 2011 | Echo Garden
I have an echo gas powered leaf blower, model pb251. it will start and idol, but wont run any faster than that, and throttle cable seems to be ok.
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Apr 02, 2009 | ECHO, Inc. PB-251C Handheld Blower
ECHO, Inc. PB-251C Handheld Blower Logo
526 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
