Question about Dynex DX-LCD19-09 19 in. LCD TV
I have a dynex TV yesterday I turned it on, and there was no sound (no previous indications this would become a problem). I've checked and the mute is not on. Any guess what might be wrong?
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: We have the stereo hooked up to the dynex 42
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Posted on Nov 19, 2009
SOURCE: I have a 40" Dynex TV
You have a fault in your video circuit, a proper diagnoses will need to be performed to tell where the problem is occurring.
Posted on Sep 21, 2012
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Venturer Tv to Sky
It sounds like your TV is on the wrong input. Look for a button that says input or source. Depending on the TV this will either provide an onscreen menu to select an input or it will simply scroll through the inputs. Turn on the Sky box and run through the inputs until you see something that looks like your Sky Box.
Jul 26, 2013 | Televison & Video
Sep 20, 2012 | Dynex Televison & Video
Dynex 47
This is exactly why I tell people that when your set isn't working, you have to have it properly diagnosed. Chances are you have a defective main board. The power indication is an indication that you have standby power. However, the power indicator is controlled by the main board. So it is likely that your power supply is fine but you have an issue with your main board. It is not likely that your replacement power supply is defective as well, but anything is possible. You will need to have the power supply tested. If you are handy with a multimeter, I can help you with that.
Sep 03, 2012 | Televison & Video
Dynex DX-24L150A11 won't turn on LED light is not on either
Sounds like you are missing your 5VDC standby voltage from the power supply. You either have a blown fuse or a defective power supply. Did this happen out of the blue or after a T-storm???
May 11, 2012 | Dynex DX-L42-10A 42 in. LCD TV
Dynex 32 in only shows black and white now
Black and White on a new setup would indicate you've plugged in AV or Component cables incorrectly. Match the colors up, be aware some Dynex models have AV connections on the SIDE of the TV. Don't just plug colors into random places. Failing that, check to see if your still inside 1 year manufacturer warranty or a best buy product protection plan. If not, seek out repair locally.
May 15, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
37" Dynex TV won't turn on
TV IS 2 YEARS OLD SAME PROBLEM AS ABOVE
Jan 04, 2009 | Dynex DX-LCD37 TV
Dynex DX-LCD19-09 19 in. LCD TV Logo
192 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
