Question about LG LHD45EL Dehumidifier
Hello Our LG HDL 65EL is not working properly. It turns on, the compressor sounds like it want to go, but the fan doesn't turn on. Is the fuse we can replace or a reset button we can switch? Or is there anything else we can chekc??? Thanks Cinamon
    Brigadier General:
  • 4,736 Answers
No, there is no fuse or circuit breaker to reset on your unit. However, there are several things r=than can cause the problem, you're experiencing:
The unit's humidity level may be set to high. Lower it to 35%
The air intake filter may be dirty or clogged. Remove the filter and clean it
The compressor coils may need cleaning.
The air ambient air temperature may be to low. Dehumidifiers don't function well between 40 & 60 degrees F.
The unit may need to reset itself. Turn the Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. Plug it back in and turn the Master ON/OFF Switch to ON. Set the humidity level to 35%. Allow the unit to operate in Automatic Timed Mode, rather than continuous mode.
Make sure there is at least a minimum of 12" of clear air space around the entire unit, when in operation.
If none of the above solves the problem, the humidity sensor may have failed. In which case it should be replaced. Or the compressor needs to be recharged with refrigerant.
I hope this helps you troubleshoot and solve the problem.
Posted on May 27, 2011
Kenmore dehumidifier compressor on but doesn't collect water
clean the condenser in the front or the filter if it has one. no air flow to cool it down will result in overheating and no condensation collection across the evaporator coil.
May 09, 2012 | Kenmore Dehumidifiers
I have a DDR7009EE and the fan runs continuously even when the humidity in the room is below the setting on the machine. Shouldn't the fan stop when the desired humidity is reached?
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Jul 28, 2011 | Danby DDR5009EE Dehumidifier
Have a Goldstar Dehumidifier GHD30. Approximately 2 years old refurbished. The fan will run on the lowest setting but the compressor does not start. When I turn the dial to a higher setting the breaker...
doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
Jul 25, 2011 | LG DH30 GoldStar Dehumidifier
Runs but doesn't work (no water accumulates)
It sounds like what you hear working is the fan. The unit also has a compressor; if the compressor is bad or the freon is gone, the fan will run but the coils wont cool to remove moisture from the air.
Jun 26, 2011 | DeLonghi DE500P Dehumidifier
I have a Danby Silhouette and the fan works but the dehumidifier doesnt.
Bryan, it may imply be a case of the humidity extraction level being set to high. Lower the level to 35% and see what happens. As far as the fan running is concerned. Most dehumidifiers are designed for the fan to run, even if the compressor doesn't turn ON. It's designed to keep the air circulating and if the humidity rises above the setting you have it on, the humidity sensor will pick up this change and turn the compressor ON.
Also, remove the air intake filter to see if it's clogged and needs cleaning. Maintain at least a minimum of 12" of free air space all around the dehumidifier. Poor air circulation will prevent the unit from working properly. As will, to low an ambient air tempeature. Most unit struggle to work at temperature between 40 & 60 degrees F.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 04, 2011 | Danby DDR451 Dehumidifier
Unit is not pulling any moisture. I took off the cover and removed all the lint buildup on the coils and filter and it still doesn't work.
So far, you've completed all the right tings, that I would have suggested. Now, take a look at the humidity setting on the dehumidifier. If it's set high (above 65%) there's not much chance that the unit will collect any humidity. It simply is just maintaining what it's set on. Lowering the setting to 35% will have a much better affect in removing the humidity/moisture.
There is an in home test you can do, to make sure the unit is working properly. Place the dehumidifier in the center of a bathroom and turn the shower ON hot enough to generate steam. Turn the humidifier ON and Set the level at 35%. Do Not turn the bathroom's exhaust fan ON or leave a window open in the bathroom. As you exit the bathroom, close the door and wait 15 to 20 minutes before returning. After entering the bathroom, turn the shower OFF and allow the unit to run for 5 more minutes. Then check the bucket for signs of water. If you find any, the unit is working as it should. Also. the dehumidifier, when in operation should have a minimum of 2 feet of clear air space around it. The fans on many units run almost constantly, to recirculate the air and if any increase in humidity is sensed, the compressor will turn ON. This is particularly true, if you operate it in continuous mode, rather than a timed mode. Also, be sure that all exterior doors and windows are closed when the unit is in operation.
If after doing the in home test, the bucket did not show any signs of water, either the humidity sensor has failed and needs to be replaced or the compressor needs to be recharged with refrigerant. If you don't feel comfortable trying to repair the unit yourself, the following is a link that will help you locate an authorized LG Repair Center in your area.
http://www.lg.com/us/support/repair/support-repair-provider-lookup.jsp
Find out what the cost to repair the unit will be, before committing to it. As your model has been discontinued and it may be less expensive to but a new unit. Hope this helped you. Please let me know.
May 25, 2011 | LG LHD45EL Dehumidifier
Re: Kenmore 54501 dehumidifier. Both fan and compressor sound as though they are turning on, but no water is evaporated into the water bucket. The unit had always operated properly during past seasons,...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 24, 2011 | Kenmore 54501 Dehumidifier
The compressor does not kick on - this is the second one I have purchased in the last couple of years and believe there must be some things I can check out on my own. I only run it during the summer...
Yes, there are some things you can check.
The first thing to check is the setting on the Dehumidifier. If it's above 60%, it's not likely that the compressor will turn ON, as 60% is a pretty high humidity level. Keep in mind, if it's set at 60% that's what it will maintain, not remove. Lowering the level to 45% will have a much bigger effect.
Now, let's suppose, after turning the setting down, it doesn't cause the compressor to turn ON.
Take the unit into the bathroom, plug it in and turn it ON, with the Humidity setting at 45% or lower. Turn the shower on, using hot water and on the way out close the door. DO NOT run the exhaust fan in the bathroom. Wait about 15 to 20 minutes, return to the bathroom, turn the shower OFF and check the water collection bucket for water. If any water is in the bucket, your unit is working as it should.
Routine Maintenance:
Check and clean the air intake filter regularly. A clogged filter causes the compressor strain to keep up. Also, cleaning the coolant coils prior to using it in the Summer, can go a long way. After cleaning, a light coat of WD40 really helps.
May 17, 2011 | LG LHD45EL Dehumidifier
The dehumidifier runs, cycles on and off, but there is almost no water in the receptacle. I haven't had to empty it since it started cycling on & off this season. I usually have to empty it at...
You may have the humidity setting to high. Try lowering it to 45%. Or if yours doesn't have an LED Screen, set it for minimum. Also, check and clean the air intake filter, if you haven't already. Keep in mind, most dehumidifiers have a fan that may seem to run constantly, but the compressor doesn't turn ON. The fan is circulating air, in a effort to detect humidity levels that are higher than what you have the humidity removal set on.
May 10, 2011 | LG LHD45EL Dehumidifier
LG LHD45EL Dehumidifier Logo
165 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
