Question about BOSS AUDIO SYSTEMS BV7320 Car Video Player
I have a bv7320 head unit i am trying to install into my ford ranger. i have all of the wires matched up and im not getting any power to the unit. i have a amp powering all my speakers and a seperate one powering my sub. i have no idea why its not turning on
  • 625 Answers
Since you did not mention the year of the vehicle, I cannot be sure of the power/ground connection. However, if you are sure of the connections, let us proceed. Check the constant 12 volt for power. Check the accessory power connection for 12 volts when the key is on. Check the ground connection for a good chassis ground. If you do not have power at these connections, check your fuses at the vehicle fuse box and at the stereo head unit itself (if one exists). If all power and ground connection are good and all fuses are good and, your unit still does not power on, check and make sure that the pins in the stereo harness are properly seated.
If all of these things check out as good then the issue is with the head unit.
Posted on May 27, 2011
Is there a ground wire in the stereo wiring harness in a 2001 plymouth neon? if so what does it look like?
Usually the wire is green or black. Best to use a multimeter to check these right and not make a mistake as if you are not tech savvy a meter will steer you to do hook things up right.
Sep 01, 2012 | 2001 Plymouth Neon
I have a 87 ranger with a 2.9 v6, im not getting power to the rear fuel pump can you help me?
th problem is comning from the engine control unit but u csn put the head rely
Mar 09, 2011 | 1987 Ford Ranger
Color codes do not match my new radio can not get any power to the radio
Do these colors match your truck wire colors? Let me know if not or if you have more questions.
1991 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Oct 16, 2010 | 1991 Ford Ranger Supercab
I got a 1998 ford expedition eddie bower and im trying to install a radio i just bought and i need to know the colour coding from the car eglike power wires and speaker wires
just get the harness kit from a sound shop/bestbuy/walmart. it plugs into your car harness and has wire colors that match all the wires on the radio. it makes it fool proof and a breeze.
Oct 07, 2010 | Car Audio & Video
Fuel tank selector solenoid on a 1988 ford ranger. It wont select between the two tanks. Am i supposed to have voltage at the switch in the cab or does it originate from the solenoid?
The switch in the cab may be a ground. If you can trace the wire to the solenoid looks for power coming out wire color and see if they match to the tank.
Of course check all fuses and wires. Did you pull a wire lose driving over debris?
Also check the hose to the tank from the switch.
Removing the switch and testing it away from the fuel is safest.
With that many years on the truck I suspect switch failure.
Good luck with it - let me know any progress.
Jan 28, 2010 | 1988 Ford Ranger
Need help installing a sony stereo in a 1988 ford ranger, need to know what colored wires do what
Theres a standard amongst most stereos, so if these colors apply, then you will be right,
Red is Ignition power
orange is direct power
Black is earth
blue is for phone
White is for electric arial
then there will be four coloured wires with matching color trace wires, these are the speaker wires.
Hope this gets you going, good luck.
Jan 01, 2010 | Car Audio & Video
1998 ford escort sound
check speaker wires on check connections
Mar 04, 2009 | 1998 Ford Escort
I need to install a max385vd in a 2002 pord f-350, do i need an install kit?
Regardless of whether this is an amp or a head unit, an install kit is either very helpful or necessary. If it's an amp, you'll need it for sure - you can't power an amp with 18 gauge factory power wiring like a head unit can use. You need to get at least 10 gauge power and ground wire, 18 gauge remote turn-on wire, and RCA patch cables to conduct the sound. If you have a factory head unit, you'll also need a line-level adapter to give you a source for the RCA patch cables.
If this is a head unit, you'll need the adapter harness to plug your existing stereo harnesses into the new head unit. It makes it simple - the wires on the new head unit are color-coded for what they do, and the adapter harness is identically coded. Match the colors, then plug it in. You may also need an antenna wire adapter (some cars require this).
Aug 10, 2008 | Clarion Car Audio & Video
Ford ranger headlights
check your head light switch
May 25, 2008 | 2003 Ford Ranger Regular Cab
BOSS AUDIO SYSTEMS BV7320 Car Video Player Logo
340 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
