Question about HP Pavilion m7760n PC Desktop
How to take out cage---need to replace psu----hard to unplug 24 pin also is their manual for the disassembly hp m7760n desktop
  • 134 Answers
Is not that hard but before you start this task you should un plug any cable at least half hour before for better results. theres a press pin in the middle just pull it out and all the type molex connectors...replace the power supply for an compatible psu...the same watts power is very inportant in order to avoid blue screens and boot failures..good look
Posted on May 27, 2011
Green light is on pwr suppy. +12 and +5 volts a little low. Power_On volts goes from +4.8 to 0 at startup on 24 pin pwr connector.computer beeps 3 sec.off and on till turned off. HP Pavilion 7955
Pavilion 7955 , 1997 year.a very old Pentium 4 , Desktop the PSU is bad.
its only worth for the trash, any P4 puter, it's junk .
4.75vdc is low as is allowed.
did you jumper test the PSU first.
the MOBO and thE PSU can both turn it off.
so can shorted modules, remove all not needed things first.
dvd , and all hdd .
all usb.
all memory but 1 stick in bank 0
even remove video card. if it has one, must now turn on.
unplug the 24pin, and place the jumper seen here
the PSU must run, if not the PSU IS TOAST.
if it does run we top the mobo unloading, of all things that can short out..
http://www.pcdied.com/power.html#Jumper
Oct 21, 2017 | HP Computers & Internet
Dell Inspiron desktop, will not power up.
hi!,
ok, is there any voltage appear in one of the terminal of psu or power supply is the fan of psu is running,if you suspected your psu is running or not try to unplug and disconnect your psu from the mother board,then bigger socket that contain 24 pin with different color of your psu try to connect the two pin that has a color blue and green by a small wire about 2 inches slotted at both end.then put power if the fan is run its good may be your memory or video card or processor is defected if your psu does not run replace.
Mar 05, 2012 | Dell Dimension 3100 PC Desktop
Power button on dell 5000 flashing amber
***I'm pretty sure your power supply is dead, you will either #1 take to repair shop or #2 replace it yourself.
The Best Value 550W Gold PSU 12cm 24-Pin 550 PSU is compatible.
The Corsair Memory 550W VX PSU is compatible and Corsair is an excellent brand, but you may have an issue locating the excess power connectors inside the case.
The Xilence XP480-12R Power 480W Quiet PSU would be fine, providiing the "hard drive connectors:2', are 4-pin Molex connectors.
Aug 04, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I bought a HP 6710f Pavillion desktop, running windows 7, and found out it only has a 250 watt power supply. I turned around and bought an Antec Greenwatts 500 watt ATX 12v v2.3 psu to install for future...
Presuming you mean the Earthwatts 500:
Should work, though the Earthwatts has the 24 pin ATX instead of the 20-pin.
http://www.atxpowersupplies.com/manuals/Antec-Earthwatts-EA-500D-user-manual.pdf
You just need to snap the 24-pin connector apart to make it work as a 20-pin. It can be snapped back together for future motherboards.
The Bestec is just a standard ATX power supply
Mar 23, 2011 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
I would like to put a 2nd cd drive in my hp media center pc m7760n and am not finding a way to remove the expansion bay front pieces without breaking them. Am I missing a release catch somewhere? I...
Hello - It's not greatly intuitive:
You apparently have the sides and drive installation down so images below:
Install your drive and reinstall the front panel like so:
Have Fun and Thank You for Using FixYa, Mikeywaf
Feb 21, 2011 | HP Pavilion m7760n PC Desktop
Hp compaq dc 7100 psu 24 pin SLIM LINE
why wont you buy a new power supply or a plug that converts from a 20 pin to a 24 pin
Mar 31, 2009 | HP Compaq dc7100 PC Desktop
POWER SUPPLY 24 pin slim line colour code ,hp compaq dc 7100
normal white wire....?
white with red....?
brown....?
PC will not power up
Check that the ram memory hasn't come unseated from the mobo. If you are using an above board video card also check that it is properly seated as well.
The clicking noise from the PSU is kinda perplexing though...
Mar 01, 2009 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Hp media centre m1180n wont power up after power cut
most likely it was the psu. You can actually test it yourself by buying a psu tester made by Antec that you should be able to buy in stores. It's a cheaper alternative to buying a PSU and just hoping that was the problem.
Jun 07, 2008 | HP Pavilion Media Center TV Desktop with...
HP Pavilion m7760n PC Desktop Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
