Question about Cookshack Grilling
I have a smokette 009 that is years out of warranty. As we all know, the max temperature on an 009 is 250 degrees. I would like to change the temperature range to get to 325-350*. I'm comfortable replacing the needed components to do this, I don't know what the specific values should be. Any help would be appreciated. Thanks in advance- Brian
SOURCE: Hotpoint RGB745 Gas Kitchen Range
I eventually replaced the oven ignitor. That has solved the problem.
Posted on Aug 29, 2007
  • 90 Answers
SOURCE: FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Posted on Jan 05, 2008
premtech
  • 934 Answers
SOURCE: Toshiba 50H82 hyperboard caps
Service manual won't help much in the hyper board and that's likely the problem.. Simply remove the hyper board and open the can. Inside you'll see a number of smd caps. There are 11 10mf/16v that need to be replaced...
Bill
Posted on Aug 06, 2008
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
danilomanjr
  • 45 Answers
SOURCE: sumproduct or conditional sumif with multiple criteria in vba code...
i'll just reply to your conditional sumif query.
yes, you can do multiple criteria query but with a matrix formula. you may look it up. nonetheless, here is how one would look like:
{=sum(if(range1=A x range2=B x range3=C, sum range))} note that x (multiplication) is used to denote intersection of the criteria
initially, you'll enter it as:
then, edit the cell (F2) and press ctrl+shift+enter for the brackets { } to appear.
Posted on Nov 18, 2008
On low the temperature is reading 700 degrees how do I adjust
Probably bad thermometer. Double check with a cheap oven thermometer. Warranty?
Apr 05, 2015 | Char-Broil Quickset Traditional 463761006...
Why is my food freezing
If you did not put it in a freezer, but in the fridge, you have two options. The best option, because you can change it, is you did put the thermostat on a too low temperature. The other, needs repair is when the thermostat is defect, so it does not react when the temperature you selected is reached. Try to change the setting of your thermostat and buy a cheap thermometer, to monitor the temperature. There are old school min max thermometers, and new digital ones, but just a cheap other thermometer will work. You only have to look more often on the cheaper one.
Your fridge is only allowed to have a variation of a few degrees, when working.
If it is working from +1 Celcius to -2 the thermostat is working, but at least 5 degrees too low. normal would be from 5 to 7. (I don't know what it is in Farenheid, but must be around 40.
Jun 23, 2014 | Maytag MSD2554VE (250 cu ft) Side by Side...
Low Temperature
250 is not low, it is just about to boil over, coolant boils at 260 in a closed system, water boils at 120.Your car should not exceed 200, 220 max. Or just 100 degrees over the outside temp, like 87 degrees out, your car should be running at 187. Until you stop at a light and it idles for a minute, then it will climb.
Aug 04, 2012 | Cars & Trucks
I need the valve clearance of a Honda 160i SOHC, 1993 model.
Valve clearance with the cylinder head temperature less than 100 degrees Fahrenheit, is as follows:
Intake .007 - .009 inches
Exhaust .009 - .011 inches
Feb 27, 2011 | 1993 Honda Civic 4 Door
Temperature is unreliable. Temp is not what I select. I have been using a thermometer to gauge it. I put in a new thermostat and the problem has not been fixed. Now temp is usually approx 30 degrees C too...
It may be the part that connects to the thermostat is out of calibration. Some ovens use a capillary and others use a J thermocouple ... without knowing what make and model I can't tell you how to change it
Feb 23, 2011 | Ovens
Temp gauge is in normal, 200 degree, range when starting. Within a few minutes of driving goes up to 250, right below orange line. No leaks found, coolant level appears fine. Any ideas?
250 DEGREES ENGINE GETTING TOO HOT.SOUND LIKE CLUTCH FAN FREEWHEEL.IF CLUTCH FAN DONT LOCK IN OR HAVE RESISTANCE TURNING BY HAND WHEN ENGINE HOT.FAN CLUTCH IS BAD.IF FAN CLUTCH OKAY COOLANT LEVEL CORRECT.I WOULD CHANGE THERMOSTAT FLUSH OUT ENGINE AND RADIATOR.IF ENGINE TEMPERATURE STILL READS 250 DEGREES OVER FLOW JUG OR RESERVOIR NOT BOILING OVER THE COOLANT TEMPERATURE SENSOR FAULTY.
Nov 05, 2010 | 2003 Chevrolet Avalanche
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Grilling Logo
Top Cookshack Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Cookshack Grilling Expert? Answer questions, earn points and help others
