Question about Kenmore Sewing Machines
After starting to sew the sewing machine stop. It seems to ne getting tight up at the top of the machine. It is threaded correctly. Do you have any suggestions?
  • 415 Answers
This is not what you want to hear but... recheck the threading yet again. This time totally unthread it and start again. Look at the spool that holds the thread and where the thread is coming off of the spool itself. Look to see if the little notch you take the thread out of when you first open a new spool is catching the thread as it turns on the spool. If there's a possibility that is happening make sure that end of the spool is at the top. Sometimes the thread will get catch and therefore refuse to move when it is on the bottom side of the spool.
Also check to make sure the thread isn't wrapped around any of the guides and once again check to see that it is threaded correctly.
If it isn't just the thread breaking but the machine itself seeming to lock up and not move then you need to take it in for servicing.
Posted on May 27, 2011
Can't get tension right have adjusted tension dial but when you pull the thread it just pulls out like tacking stitch
make sure that it is threaded correctly between the tension plates
correct tension is when you pull the thread as if to thread the needle there should be a slight resistance to you pulling the thread
Apr 22, 2017 | Sewing Machines
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
Bobbin does not sew: the upper thread gets tangles underneath but the bobbin thread is not involved
bird nesting indicates that the needle thread tension is not tight enough
pull the thread out as if threading the needle and the tension is close when there is resistance to pulling the thread
Oct 11, 2017 | Brother Sewing Machines
I have a hyundai 8 stitch sewign machine been working brillant but last night it kept missing the tread and the thread breaking or jabbing . today looking at it i see when it jabs the Bobbin Case Inner...
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
if the sewing machine has a top loading bobbin, you may have to have the sewing machine checked to see if there is something wrong with the bobbin case or the hook and hook race.
I suggest try a new needle--one for the fabric being sewed
also try another bobbin
rethread the sewing machine top and bobbin, using every thread guide.
Aug 21, 2013 | Sewing Machines
I just bought a singer stylist 9100 and its driven me to tears. The bobbin thread keeps couching through the top of my quilt, pulling the top stitches into a tight blanket stitch looking mess. I have...
Suggest you check your bobbin tension, pull the bobbin thread and if you feel it too loose, most likely bobbin thread not threaded correctly into the bobbin case tension plate. Do refer to your manual if you have one.
Jul 18, 2013 | Sewing Machines
Top thread breaks
The needle thread breaks
8. The needle is not the correct one for the fabric
9. Rethread the machine
Apr 18, 2012 | Sewing Machines
The machine does not seem to want to do a straight sew the underneather is gathering alot of thred and none of the stiuches are quote .. locked in they pull out easily and this just started
I suspect you have not threaded it correctly. Try re-threading both top and bottom threads. If this does not solve it then the tension may need adjusting. Upper too tight or lower bobbin too loose. A blunt needle can cause strange problems too, try changing it to see.
Dec 07, 2010 | Brother CE5000 Computerized Sewing Machine
Thread jammimg on the underside when sewing
This is usually caused by the machine being out of sync. The first thing I would try is a brand new needle. Even a slightly bent needle can cause this problem. Make sure the needle is in correctly and tight. Next make sure you treaded the machine correctly, making sure that thread goes into the top tension properly. The top tension should be calibrated to be in the middle. I would slowly turn the handle making sure the stitch looks proper. From there try tightening or loosening the tension until the loops on the underside start to get smaller until they look tight but not too tight or you'll start breaking the top thread.
I would use a standard 14 needle with some standard medium weight cotton to calibrate the unit.
Hope this helps. Let me know your results
Aug 23, 2009 | Euro-Pro 416 Mechanical Sewing Machine
When i use sewing cloth in backside the thread will too loose then i use tension tight it correct in 8 number but manual book says 4 or 5 is correct wat can i do help me
Unthread your machine and set the tension to 4.5. rethread your machine up to the needle and then put the presser foot down. If the thread pulls hard, your machine is threaded right if it pulls easily, the thread is not thru the tension wheel correctly.
Rule of thumb:: loops on the top, problem on the bottom.
loops on the bottom, problem on the top.
May 15, 2009 | Singer 8280 Mechanical Sewing Machine
Bobbin on a Viking #1+ sewing machine
Could be the bobbin case tension is too tight--are you using a thicker thread than usual? Also, check to make sure that it is the correct bobbin for your machine--several are very similar but if not exact, will not sew properly. Also, if the thread is not evenly wound on the bobbin, there would be problems. Check to make sure the bobbin thread is threaded through the bobbin tension. It may help to tighten the top tension, but if the bobbin case tension is too tight, adjusting the top tension will not completely resolve the problem. The tension is correct when the top and bobbin threads meet in the middle of the fabric--this means that whenever you start a different project, you may need to re-adjust the tension.
Understanding Thread Tension Threads
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 19, 2017 | Husqvarna Viking 1
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
