Turns on but will not boot up. LCD does not turn on and HDD does not spin. Running Ubuntu
    Sergeant:
  • 207 Answers
Remove your battery pack. Open the case and replace your RTC battery at the moment then try powering up your system again.
Posted on May 27, 2011
How can i see files created in windows os after installing ubuntu 14.04 tls
when you computer turns on it should automatically ask you what os you would like to boot from. on a side note of you go into your harddrive you should find a folder named "windows" or
"windows old" and all the files you saved should be in there. seems to me that u install'd ubuntu over windows and now only have ubuntu on your computer... but you should still have that windows folder if you chose not to delete you files.making a new partition does not mean you will have 2 os's on your computer... hope this all helps.
Jun 29, 2014 | HP 2000-369WM AMD E-450 DC 1.65G4GB 320GB...
I just installed a brand new HDD (Toshiba MK6034GAX). This is the same model HDD that came with laptop. Trying to install Linux (Ubuntu). Can I do a clean install from the USB port? I have a Toshiba...
Yes as long as you make sure in BIOS you have it set to boot from USB before the HDD.
On the Ubuntu site from the download page are instructions on how to create a bootable USB for Ubuntu.
Comment if you need any further help.
Sep 13, 2011 | Toshiba Satellite L25-S121 Notebook
Tecra A10 won't boot up. Laptop was dropped when running and froze. Shut it down to reboot but doesn't work at all. When the power button is pressed, the HDD LED illuminates for just over a second and then...
I suggest try going to Local Computer Centers, Have them check what hardware's are having problem, most likely there are problem with LCD, Motherboard, HDD.
Apr 21, 2011 | Toshiba Tecra A10 Notebook
Os can't boot from hdd
you must use livecd to boot your hdd,then back up all your files to an external hdd,then you are going to reformat your drive to boot it normally.use a working pc to get files..in iso format...save it then burn with your iso burner..you can get the files here>http://www.ubuntu.com/getubuntu/download
After you've burning,turn on your not booting machine ,place it to cd drive of your machine and it boots,insert your usb or an external hdd then copy all files needed
Feb 10, 2011 | LG Computers & Internet
My sister has a two-plus-year-old MT6840 that just had the battery replaced. However, both before that issue and since she has had trouble with her display. The computer will load as though it is starting...
The easiest way to narrow down the problem would be to boot the computer with a copy of Ubuntu.
You can either create a boot cd or convert a flash drive into a bootable drive. The flash drive boots much much quicker so I definitely recommend you following the creation method for that on Ubuntu's download page. If you don't have a flash drive, don't worry, the boot cd will still work ;)
One thing to note is your computer's boot order. Usually pressing F12 on a Gateway will bring up a temporary menu so you can select your copy of Ubuntu. If not enter the BIOS setup menu and change your boot order.
Once the Ubuntu launch screen comes up just choose TRY UBUNTU this will create a live session.
If Ubuntu works without any hitches then it's likely a Windows software issue OR a hardware issue.
You can run a trail version of HDD REGENERATOR to physically scan the hard drive exactly like Ubuntu, LIVE.
If it comes back clean then YES, it's a windows software issue. Which entails more testing and button pushing.
Try the above and let me know how everything turns out.
Jan 03, 2011 | Gateway MT6840 Notebook PC
Dell Latitude D410 - OS won't boot only after a few minutes
Seeing that both OS's (Windows XP and Ubuntu) are having a problem booting up, I also think the problem is with your HDD. I think you have a pretty good idea about computers from your use of terms :) There may be some corruption with the HDD. I would check that out first.
Good luck with your problem and thanks for using FixYa.com!!
Apr 18, 2010 | Dell Latitude D410 Notebook
External hard drive please helpmalfunctioned when
Well if the Ext. HDD is making any kind of noise like spinning up
and spinning down , or a clicking sound the unit may possibly
never run again , if the unit does boot but is not recognized by
your computer try troubleshooting start first with the power outlet
then the power cord then the data cord , make sure its running
when your computer is turned on , there is only one connection
from an Ext. HDD to the computer and that's its data cord , if its
a 3.5 HDD install it into a PC as a slave to try to recover the data
and never for any circumstances place an OS on your static Ext.
HDD , if your HDD never turns on again there are many services
online who specialize in HDD data recovery , if you attempt it
yourself you'll need a pretty close match HDD , a very clean
room a pair of non-powder latex gloves and some tiny Torx
head drivers , a clicking sound is the pick up heads , a spinning
up and down sound is the motor , if the unit needs to be formatted again you will loose the data that is stored on it
sorry I can only help so much , and troubleshooting is always
the best bet , try taking the enclosure case apart and make sure
everything is connected .
Feb 05, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Need to reconfigure start up on IBM computer. Windows xp at present, want to put Ubuntu on instead. When I press F8, I get safe mode options etc. Need to get to page before this, re: make cd drive the...
to make cd/dvd drive the primary one..all u gotta do is to configure the bios(press DEL/F1/F2/F10 briskly, as applicable while at the system boot, this'll enter u in the CMOS utility, search for boot Device Priority)..make cd/dvd drive the primary or 1st boot device n 2nd device @ HDD 0..
download n install any boot manager (various are available)..eg. Power quest Boot Magic..it'll b quite useful when u wanna selective startup using Multiple OS like win xp pro sp2+ubuntu..
the best is to install ubuntu first in raw/undefined hdd space next go for xp..
always better to seek professional supervision of ur System admin/vendor....
Nov 04, 2009 | IBM NetVista PC Desktop
My MSI P6NGM-based system stopped working. On
Parity is a memory ( Ram problem ) try removing 1 Stick. or changing it into another slot. if you suspect Bios. remove power cable. locate The CMOS Battery. remove for 10-15 seconds, And replace it. this will reset the bios to it,s default settings. you,ll know if your asked on boot-up to run setup to change time/date.
Mike @ Compurepair.
Sep 05, 2009 | MSI Computers & Internet
Hi! i have been trying to install ubuntu on my windows xp with my fp 5315 monitor, while the screen was loading up for ubuntu, it said something about a signal output and the screen goes black and the...
Did you try booting from the Ubuntu cd and ran the desktop live cd demo ? That will bypass the windows drivers and uses ubuntu stuff only so if that worked your instal should have worked. It sounds like it doesn't like your video card as a guess.
I've never had that problem in a install but I would bet they have on the ubuntu support forum.
http://ubuntuforums.org/
I think you will be able to get your answer there. If you can't find it using the search ( I tried. didn't) then post it and give a bit more info such as ubuntu version, and so on. Lots of good help there. Once you get it running you will be quite happy with it.
Aug 21, 2009 | HP Compaq FP5315 15" LCD Monitor
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
