Question about Quantum PX502 (PRA22AAYF) Ultrium Tape Drive
Quantum PX502 tape library is showing a "Servo
    Brigadier General:
  • 8,546 Answers
Look for a physical reason for the robot to stall.
http://www.quantum.com/ServiceandSupport/SoftwareandDocumentationDownloads/PX502/Index.aspx
http://downloads.quantum.com/px500/PX502_Quick_Start_Guide_81-81292-03_B01.pdf
A tape may be sticking out of its cell or a drive.
Never use sticky labels anywhere on the cartridge.
Posted on May 27, 2011
  • CJA333 Nov 16, 2011
    I released both magazines to see a tape still in my drive. I reached in and was able to remove it without any resistance. I know that sometimes tapes will be in a locked position and I cannot simply pull them out. For those I have been able to press and hold a button (forgot label over years) for 30 seconds and it will go through the motions of spitting it out. I noticed that there is a small microswitch on th circuit board of the tape drive, but did not have to use it. After removing the tape I reinstalled the magazines and performed another reboot of the library as I type this.
    Yay... scary reaching in to grab tape, if you choose this route, be extremely careful of touching anything except the tape.
Servo init failure stalled xy
Hi Edouard
This sounds like the picker has failed to complete the power on self test (POST).
This may be due to a damaged library or simply due to a tape blocking the picker movement.
POWER OFF!
Try opening the library to make sure your tapes are all properly located in the magazines and have not fallen out.
Also try gently moving the picker to see if you can locate any other obstructions. Be very careful as you obviously do not want to break the picker or anything else accidentally.
If you are in the UK and are still having trouble, click the link below and we will do what we can to help.
LTO Repair service UK Based All manufacturers of LTO drives repaired
Feb 28, 2014 | Quantum SCALAR 50E LIBRARY LTO3HH TAPE...
QSB channel failure
Hi Tom
I am not certain but it sounds like the tape drive might not be seen by the library.
Try removing and re-installing the drives into the library.
Jan 08, 2014 | Quantum PX502 (PRA22AAYF) Ultrium Tape...
Scalar 50
http://downloads.quantum.com/scalar/S50/manuals/81-81539-01_A01.pdf
The above may be helpful but i cannot see the error codes listed. This unit is the same as the PX502 so this may also help
http://www.sandirect.com/documents/PX500_Series_Users_Guide_81-81290-05_A01.pdf
Try also going to http://tape-drive-repair.com/ who have a repair centre to fix tape library units.
May 11, 2013 | Quantum Scalar 50 Library, One LTO-4 Tape...
My Ca Arcserve is showing that the quantum superload is constantly busy. I can not do anything as it also says that it is busy. I have shutdown and restarted the quantum drive a few times and all still...
power down both the library and computer, disconnect the library, power up the library. Check the operator panel of the library for an online ready status.
Jan 13, 2011 | Quantum SuperLoader 3 LTO-3 Tape Drive
Servo init failure stalled xy in quantum scalar 50
The unit will need to be repaired.  Consider getting a maintenance contract on it as my px502 cost me $700 to replace a sensor and cleaning and a few other minor issues.
Jan 19, 2010 | Quantum SCALAR 50E LIBRARY LTO3HH TAPE...
How do I remove a stuck tape?
Power the unit down and very carefully unscrew the cover.  The greatest care must be when taking the tape out so that you don't bend the unit.
Consider blowing it out to get rid of dust and it very likely has a problem that will require service.  My quantum px502 had a stuck tape and I took the cover off but the picker was already off track - $700 to fix that and replace a sensor.
It gets heavy use and was serviced before in the three years it has been running.
Jan 18, 2010 | Quantum DLT-V4 DLT Tape Drive
Tape won't eject
Soft power the unit down and very carefully unscrew the cover. The greatest care must be when taking the tape out so that you don't bend the unit.
Consider a maintenance contract as on visit to the repair shop will cost hundreds of dollars.  And, if you get the tape out another will likely stick soon.  So service will be necessary.
Jan 08, 2010 | Dell PowerVault 114T (0CC011) LTO-3 Tape...
Quantum superloader not showing in windows device manager
First off, I have to say that I have had nightmares with Quantum tape libraries. It is possible that they are still manufacturing lemons. I had one replaced 4-times and it still did not work!
Start troubleshooting by making sure that it is identified by the controller card it is connected to. You should see this during the server POST before Windows starts. If you don't see it there then Windows definitely won't see it. Send it to Quantum for service.
If the controller sees it then make sure that you are using the Backup Exec drivers. Never use the manufacturer's drivers with Backup Exec. Veritas, now Symantec, has a downloadable utility called the Device Driver Installation Wizard that will make sure you have the correct driver loaded.
I hope this helps.
Nov 13, 2008 | Quantum SuperLoader 3 LTO 2 Tape Drive
Quantum Error
The host backup application probably still has ownership of the library. You normally need to select to 'open door' or something similar to release ownership back to the library
Jun 20, 2007 | Quantum PX502 (PRA22AAYF) Ultrium Tape...
Quantum PX502 (PRA22AAYF) Ultrium Tape Drive Logo
1,118 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
