Question about JVC HD-52G886 52" Rear Projection HDTV
My jvs tv the sound works but no picture someone said the flyback was bad
    Genius:
  • 1,030 Answers
This is a dlp or digital light projection tv. This set uses a bulb. First check the bulb. The bulb can ussally be removed from the set from the back with a screwdriver. do not touch the bulb front. this set does not have a flyback. 90 percent of the time the bulb will shatter when bad.
Posted on May 27, 2011
  • malcolm hough
    malcolm hough May 27, 2014
    no sound is an audio problem,if you have a picture and no sound check your audio plugins or use an audio cable from either dvd player or cable HDMI box
51MP392H/17 Makes Zapping sound on power up. No picture or sound. Has been reset/unplugged. When powering up makes a sound like a bug zapper for about 1/2 second. Power light stays on and I can hear the tv...
The Zapping sound you are referring to is most likely due to arcing of the flyback(high voltage transformer). It is strongly recommended that you do not turn on the tv and have a tech test the flyback and replace it. The FBT generates voltages of about 30000V and should not be handled by someone who has not worked on high voltage electronics before.
Feb 09, 2011 | Philips Magnavox 51MP392H Rear Projection...
My TV
the old ticking sound... yes.. it means your power supply shut down and continously trys to reboot ... hense the tick sound as the voltage rises and fails.
Means you got a short somewhere. Most likely the obvious high power consuming High Voltage Suppy... and as I found in 99.9 percent the Horizontal power Transistor shorted... 80 percent Flyback, 10 percent audio... 10 percent some odd circuits like vertical or yoke as shorted.
you have a short.
Sep 10, 2008 | Sanyo DS24424 24" TV
Tv wont come on
Most times when you hear this kind of sound on a TV it is because the flyback transformer is bad (from what I can remember anyway!). Its been a while since I repaired TV's, so hopefully someone can verify my info. The flyback transformer steps up the voltage very high which powers the color tubes. If that is bad, you will get the thunk sound. Also, if memory serves me well, there is a high power output chip that could be bad as well. Please, anyone who knows TV's, please verify for me. It has been years for me!
Apr 13, 2008 | RCA R52WM24 52" HDTV Projection Television
Picture and sound went out suddenly on a Sony KV-35S40
sony has problem with bad picture tubes as well as flyback transformers .if you have shorted hori output then replace it if set shorts it out again your looking at bad flyback transformer as well as maybe leaky tube.
Oct 27, 2007 | Sony KV-35S40 TV
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
Picture goes off but i have sound
I got KV 32ts 46 Sony
Turn on TV and seems OK, then no picture but have sound. I turn it on and off some time pictures come back but goes out again. Pleas help
Oct 19, 2007 | Sony KV-35S40 TV
TV picture doesn't work
That sounds to me like a flyback transformer went bad. I just had this issue because the ceramic coating on my flyback cracked and caused it to arc off. I got a new one delivered for 31.90 and soldered it in and viola! Perfect 32" tv once again.
Sep 02, 2007 | Zenith C32V37 32" TV
Sony WEGA KV-36HS500
you may have cracked the circuit board when moving , sounds like a bad vertical circuit. look for bad connections around vertical ic or flyback transformer
Aug 19, 2007 | Sony FD Trinitron WEGA KV-36HS500 36" TV
56" RCA projection TV (FLYBACK related problem)
the base to emitter of the hot will read short on a diode checker/test on ohms it vairies but typically about 50 ohms.e to c, or b to c should have very high resistance. unsolder the collector of the hot. make sure all solder is gone. now test the ohm between your tuner ground & the pad of the hot collector it should read open.
Jan 16, 2007 | RCA P52921 52" Rear Projection Television
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
JVC HD-52G886 52" Rear Projection HDTV Logo
90 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
