Question about Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard
3 beep sound-no boot
I am having the computer with Intel 845GVSR motherboard,P4 Processor,128 MB RAM Configuration. When i switch on the system, three beep sounds come and the system is not booting. But the RAM is in working condition.No problem in RAM. One day there was a melting smell from my system.Immediately i switched off it and i felt some heat in the first end of the memory slot. Because the RAM is not in the position at the time. Fromthat time onwards it gives this problem? I am not using PCI slot or any card.
  • Anonymous Sep 07, 2008
    hello
  • Intel Master
  • 19,396 Answers
That means a short in contacts on memory slot, or a component on board melting down.
If this happened it is possible that the motherboard is faulty.
If you are lucky the motherboard will read memory on one of memory slots, more likely it wont read memory at all.
Due to the cost of labor required to test and fix the motherboard usually it is worth replacing it rather than fixing it.
A P4 motherboard starts from around $50, on Ebay you can find tested and guaranteed second hands from $20.
Posted on Aug 16, 2008
SOURCE:
Display Problem with Intel 845GVSR MB : My computer running on Intel 845GVSR MB with 2.4 GHz Intel Pentium 4 Processor and 768 MB RAM and 80 GB HDD . When I start the computer nothing appears on...
Reset the CMOS setup after putting the battery. You have 768MB RAM. So check with the alternate memory module with different slots. If not helpful, check the RAM with another PC. Lastly get the BIOS updated or motherboard repaired from component level motherboard repairer. You may have damaged the motherboard by putting undue pressure while plugging the connectors.
sonsunny
Jul 08, 2011 | Intel D845GVSR Motherboard
I am having the computer with Intel 845GVSR motherboard,P4 Processor,1 gb RAM Configuration. When i switch on the system, three beep sounds come and the system is not booting. But the RAM is in working...
For that first open cpu cabinet then refix RAM memory try it in defferent slot on motherbord.
Pull cmos cell from motherbord for 10 minutes so all settings goes to defaults.
Then open processor fan and processor then refix both.
Clean dust from all parts.
Reconnect ATX power connector to motherbord.
Reconnect power cable and sata or ide cable to harddisk.
If any PCI cards are installed then remove it from pci clot then check.
Make sure your motherbord is not ground with cabinet check in outside of cabinet .
Let me know if you need further assistance.
Nov 10, 2009 | Intel D845GVSR Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
REPLACED MOBO INTEL D845EPI/845GVSR EMACHINE 2.5 P4 REPLACED PROCESSOR... NO DISPLAY OR KEYBOARD RECOGNIZED, NO BEEPS NOTHING BUT FANS ARE RUNNING AND LIGHTS ARE ON?
1.*********** Board not supporting Your Processor.
2. Try With Lower Speed Processor
3. Mahe sure that Mother Board is Working or Faulty.
4.Check the ram twice
If it HELPS RATE ME!
Jun 24, 2009 | Intel Desktop Board D845EPI Motherboard
System in hanging
try to replace your RAM
Jan 13, 2009 | Intel Motherboard
3 beep sound-no booting
system is on but no display. yes i did heard sound 3 beep sound from the motherboards.
Aug 16, 2008 | Intel D845GVSR Motherboard
3 Beep sounds-No boot
As you probably know 3 long beeps on an Intel motherboard is memory failure. Even if RAM is good your Motherboard may have problems in reading your ram module.
If you are using a PCI or AGP video card try also removing and putting back video card, video adapters use shared RAM and can give you troubles with RAM.
Always perform all maintainance on motherboard with power unplugged and avoid to touch contacts and circuits with your finger.
If the 1GB module is new, verify with seller that your motherboard support this memory, some motherboard do not support double density RAM.
Aug 16, 2008 | Intel Desktop Board D845GLVA...
Intel 845 GVSR drivers for windows vista
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard Logo
125 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
