Question about Oasis P1AQ
Oasis water cooler model # B1RRPK-D102. The water in the reservoir freezes! We have cleaned the system, but no improvement. Any sugggestions? Thanks, Lucy
How to properly clean my pelonis water cooler
not sure if this will help you out but have a read up.
To clean the cooler:
  1. Unplug the cooler.
  2. Check to see if your cooler is equipped with a water guard. ...
  3. If you do have a waterguard you need to remove it. ...
  4. Rinse the reservoir out with a baking soda and water solution, use approximately 1 cup of water and 2 tbsp of baking soda. ...
  5. Replace the water guard kit.
The Water Express :: How to Clean Your Cooler.
or go to this link.
How to properly clean my pelonis water cooler Google Search
Oct 30, 2017 | Pelonis Heating & Cooling
Car keeps trying to over heat and theres oil in the radiator
If your car has an automatic transmission, The transmission cooler lines attach to the radiator,The transmission cooler is located inside the radiator, It might be leaking into the coolant system. Check your transmission fluid level.
Jan 31, 2014 | Car Audio & Video
Cadillac CTS 3.6L V6 - The water in the water reservoir is mixed with what appears to be either engine or transmission oil.
If it is transmission fluid it is likely the heat exchanger (or cooler) has sprung a leak. The cooler is often integrated into the main radiator bottom tank. If fluid is entering the cooling system it is possible coolant could be entering the transmission.
Tranny fluid will appear clean and floating on the surface of the coolant and is likely to be pink or red while if it is engine oil it will be an altogether dirtier colour and more viscous. Try capturing a sample with some clean white tissue when the engine is cold.
Engine oil in the coolant could be a sign of a failing cylinder head gasket.
A failing head gasket is likely to produce unusual cooling system symptoms including ejecting coolant from the reservoir while a leaky tranny oil cooler is unlikely to have much effect on cooling system behaviour except for the obvious...
Aug 13, 2017 | Cadillac Cars & Trucks
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
Apr 06, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Cooling does not work either
Get in there with a vacuum and clean up the condenser coils then check the compressor relay. If all those are fine bypass the cold control just long enough to see if the water cooler works. Do not leave it bypassed or damage to the reservoir could occur.
Aug 31, 2009 | Hamilton Beach Water Cooler with Storage...
OASIS drinking fountain , no water
Pull the water jug and open the top of the unit. Look for frozen water. May need repaired or adjusted to keep water from freezing.
Apr 01, 2009 | Oasis P1AQ
Owner's Manual
The Oasis service manual is online in PDF format. Just type this addy into your browser and good luck http://oasis.ie/docs/en/SERVICE_MANUAL_ENDLISH.pdf
Jan 15, 2009 | Plumbing
Water Cooler - Water has mildew taste
I just put about six cups of white vinegar (not diluted) into the reservoir and let it sit for about an hour. Then I emptied that out and flushed a few pitchers of very hot water through. It seems to have worked quite well.
Jan 09, 2009 | Hamilton Beach Water Cooler with Storage...
Oasis water cooler taps started dripping
if the cooler is a hot and cold, even if its a cook and cold, the cooler always needs to be cleaned and maintained, not only on the inside but on the outside, as the cooler is used calcium builds up over time. that is why your taps are leaking, there is a build up in the taps, therefor the taps are not sealing properly and letting some water thru. i say take the taps out and clean them with vinegar.
the second thing u can do is the taps do come apart into smaller peices once u disconnect them from the cooler. take the taps apart and find the spring located within it, stretch the spring and than reconnect the peices together than reconnect to the water cooler.
Nov 14, 2008 | Oasis P1AQ
Oasis P1AQ Logo
274 people viewed this question
Top Oasis Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Oasis Refrigerator Expert? Answer questions, earn points and help others
