Question about Whirlpool Duet GHW9150P Front Load Washer
I purchased my GHW9400PT 4 years ago. Should I have it serviced - checking belts, electrical contact points, oiling motor etc? If so, how often is the ideal (the company says) and how often is realistic? It is making making some noise when extracting water - not grinding, not thumping, but more whirling. - might that be the belt?
  • 76 Answers
SOURCE: grinding noise when it goes to agitate or spin.
gramps Most likely the problem with your washer is worn out motor drive coupling. You can buy it here: http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.547094027&type=10&subid= If you need help to replace it, let me know. Gendos...post back
Posted on Feb 06, 2007
natengel
  • 19 Answers
SOURCE: repair washing machine
lid switch
Posted on Oct 31, 2007
onthejob5130
  • 640 Answers
SOURCE: Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Posted on Jan 12, 2009
jsrock516
  • 5911 Answers
SOURCE: washer does not spin makes whirling noise sounds
It probably IS your motor coupling. Just to be sure...the following link explains the symptoms of a failed motor coupling and how to diagnose the problem:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
If you've already determined the coupler to be defective, the next link explains how to access the coupler and replace it:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number is included in the instructions I provided. Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is commonly sold as part of their in-store inventory.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Feb 20, 2010
jsrock516
  • 5911 Answers
SOURCE: Whirlppol Washer Model LSQ9564MQO, 6 years old, no
You may have a broken motor coupling. Failure to agitate or spin accompanied by the sound of the motor running with no tub action are some of the symptoms you can experience with this problem. Just to be sure...the following link explains the symptoms of a failed motor coupling and how to diagnose the problem:
If you determine the coupler to be defective, the next link explains how to access the coupler and replace it:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is commonly sold as part of their in-store inventory. The average cost of a motor coupling is about $15.
If you have any questions, or if you check the motor coupling and it is still intact, please post back and let me know. I hope this helps you.
Posted on Mar 04, 2010
Will the oil pressure sensor prevent ignition to the motor? 1999 Ford Laser - KN or Mazda 323
no oil sensor not related
fuel ,spark a broken timing belt
fuel
pump or relay you should be able to hear the fuel pump working
if engine light is on
crank angle sensor
Nov 05, 2016 | Ford Cars & Trucks
Samsung UN55C6500 turns off and on at random
ghosts. actually, check your house wiring, for leaks, open grounds, etc.
Feb 01, 2014 | Samsung UN55C6500 55 LCD 1080p HDTV LED...
Machines 510
these machines can get seized bearings, which can stop the bowl from turning at full speed. probably the motor after this.the clutch should affect full spin speed only if it's worn. this fault can be a timer issue also.
Nov 17, 2013 | Hoover Washing Machines
BROKEN TIMING BELT- Testing valves, etc for damage- (1997 NEON) I have installed the larger DOHC engine in this car about a year ago. Recently, the timing belt broke. It IS an intermittent engine. I...
Think about this for a moment....You already know you have a few bent valves. Valves are serviced by removing the cylinder head. That single fact tells you that the head needs to come off to do the repair.
Once you remove the head, you will be more able to inspect the remaining valves and piston tops, then with that information, decide if you can rebuild it. A compression test requires spinning the engine and risking further damage.
Jun 09, 2011 | 1997 Plymouth Neon
1994 Dodge Dakota Sport Standard Cab Pickup automatic, i have a new battery and when i turn the key everything turns on and you hear a part of the motor but it wont start, what should i look for?
Sometimes when fitting a new battery the terminals are not on really tight. First check that the contact face of the battery terminal cable clamps are bright metal. Clamp securely so that there is no movement between cable and terminal. Next check the condition of the earth return strap from the engine back to the vehicle's frame. Again ensure there is good fresh metal to metal contact and the it is secured firmly. Next check the connection on the starter motor...clean and secure again. If still no joy then it is time to check the starter motor. The most frequent fault in starter motors are worn striker contacts. When the solenoid is engaged is moves the starter motor armature forward to engage with the drive teeth on the edge of the fly wheel. At the point of engagement the electrical contacts of the motor coil core make contact with the copper striker plates. When they become worn then contact is lost. Make a note of the make and model of the starter motor and purchase a striker plate refurb. fit (about $10 from dealer or Autozone etc). disconnect the electrical cables to the solenoid and motor, remove the two securing bolts that hold the motor to the flywheel casing and remove the motor assembly. Undo the motor end retaining bolts and examine the striker plates. Change them one at a time, I say this as it is important that the order of insulation washers and nuts are in the correct order when reassembled - using the un-touched plate as a reference helps in this. Clean, but do not lubricate the interior of the motor - oil only serves to attract grime. Reassemble and reinstall the the motor assembly. Again ensure the electrical supply cables are clean and attached firmly.
May 06, 2011 | Dodge Dakota Cars & Trucks
What tuneup services should I be getting done on my 1999 Acura TL 3.2? It has 138K miles on it and has not had a tuneup since 75K 4 years ago...
Geez! Honda kept all the mechanics out of work! Well, a MAJOR TUNE UP must be done in ur FiNE & TiME TESTED car! Replacing the BELTS including timing belt/tensioner should be done. Checking brakes and FLUSHiNG brake fluids. Checking the underchasis, bushings, wheel bearing, wheel alignment, tires and shock absorbers. Checking clutch master/slave and toping hydraulics and gear oil in the transmission for manual. Checking electrical and ECU! Change oil, spark plugs, hi-tension wire, fuel filter, and air filter! Check and top up/flush steering pump. Check and flush cooling system! Thats all! hope your car will last another 10 more years! Taah!
Nov 11, 2010 | 1999 Acura TL
I have an older, about 4-5 years, electric kenmore 96575110 dryer that will not heat. It does it turns, the timer works fine; it just will not heat.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Oct 04, 2010 | Dryers
I have a Whirlpool electric dryer several years old (front loader) that just suddenly stopped working - the left side knob that you push to start stopped turning on the dryer. I have reset the breaker at...
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
Sep 29, 2010 | Whirlpool Dryers
My 1994 chevrolet s10 blazer has digital gauges for gas, oil pressure, mph. it has stopped working all other lights such as seat belt notification..etc work except for the dig. gages so i checked the...
Hi, follow this link and contact this person-he can help you.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280268267335&ssPageName=ADME:X:AAQ:MOTORS:1123
Best reguards, Uwe
Dec 03, 2008 | 1994 Chevrolet S-10 Blazer
I have a Hoover self-propelled windtunnel, purchased 6-04. It gets light use. I have replaced the v belt 3 times, once under warranty, and it must be replaced again. It appears to be in very good...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=675093
Generic problem for all Vacuums
Posted by klsh on Jun 16, 2008
I have a Hoover self-propelled Windtunnel, purchased 6-04. It gets light use. I have replaced the v belt 3 times, once under warranty, and it must be replaced again. It appears to be in very good condition, but is stretched too big. When I purchased 2 v belts a year ago, one was already too stretched, but when my Dad took it back, the salesman put it on another model and said it was fine (Dad never mentioned this to me). Is there a way to adjust the vacuum to hold the belt tighter? Do they really just stretch out like that normally? The flat belt has never been replaced and is in great condition.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is a good idea to change your flat belt every 4 to 6 months as a rule and the V belts @ least once a year and always use the genuine Hoover belts, there are generic or replacement belts out there but they have a tendency to stretch faster then the genuine belts. What you mentioned is not unheard of and another tip is to store any extra belts in a Ziploc bags in the refrigerator. Feel free to contact your local vac dealer if you have questions or call Hoover factory and ask for tech support. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 16, 2008 | Vacuums
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
