Question about Cisco Computers & Internet
There is not enough gain on the installed antenna(1.5dBi). I would like to install an external high gain antenna to my Cisco E1000 Wireles Router. How do I do it?
  • 61 Answers
I read on the Linksys page there should be two internal antennas in the device. What is the issue you are experiencing? Does it not reach a certain distance when trying to connect?
If you are feeling risky...you can try to run your Cisco E1000 hardware with other software. I searched the database and it shows that your router is supported. I have never used this myself, but I assume you could have access to crank up the gain to amplify the signal. Wire a fan up to that puppy or some liquid cooling and see how far it goes!
http://www.dd-wrt.com/site/index
Posted on May 27, 2011
  • elena899 Jul 19, 2011
    How could I know if the units I have belong to the recall units? Can somebody help me? Thx.
When I try and install my E1000 linksys router it causes the phone line (dial tone) to disappear. Also it doesn't have PPPOA as a protocol option. Also the linksys setup software says that it is n
Don't you require an RJ-11 for a phone line, cause I don't see one on this model? In any case, the ATM protocol should be handled by the ISP modem, and the router should just pick up the established network over Ethernet.
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done. Some models come with a setup disc, but not absolutely required.
http://homedownloads.cisco.com/downloads/userguide/E1000_V10_UG_USA_NC-WEB,0.pdf
Nov 22, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Linskys e1000 reset and password
Hello from here you can download a manual:
http://homesupport.cisco.com/en-us/support/routers/E1000
You need to install Cisco Connect software.
To reset it you have to press a small button at the back of the router
With power on.
E1000 Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Good luck
Oct 29, 2012 | Cisco Linksys Wireless N Home Router...
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about Linksys E1000 cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
When I try to access my cisco e1000 router on firefox or google it keeps saying that it is busy and will not connect
Are you trying to access the setup page of the router?
Did you install the Cisco connect software on your main computer?
If you have cisco connect software installed then open Cisco connect.
Go to Router settings. Click on Advanced settings. It will open the setup page of your router.
If the cisco connect is not installed then try to power cycle the router. Unplug the power to the router, wait for 30 seconds. Plug in the power cable. Wait for 30 seconds.
Now try to access the setup page.
If that is also not working then I will suggest you to reset the router and reconfigure it manually.
Watch video.
How to reset Linksys router.
Watch Video:
Linksys router setup
Feb 24, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Where do you get cisco connect
Cisco connect is the software that comes with the router.
You might have installed the Cisco connect software while installing your router for the first time.
Once you open the Cisco connect software for E1000, you will find the password to access the wireless network.
If you have not installed Cisco connect then you can open the setup page of the router and check the wireless settings.
Dec 17, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Manual for linksys e1000 how do I connect router to my compuyer?
You can either connect an Ethernet cable from the router to the built-in Ethernet jack that most machines have OR you can install a wireless (Wifi) adapter in your computer and follow the instructions to set up a wireless network...
May 11, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Need to put a password into a router that has been reset
If you install the cisco connect software to your computer, you should un install it first to have a better access on the web UI of the E1000,
you also need to reset the router, access UI, 192.168.1.1(default IP)
go to the wireless tab and configure the wireless setting,
if you have any problem with it call 1-800-326-7114
Feb 01, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I have nt been able to connect the new router HELP
Reset your router to factory, and install software from scratch... I need more details to help you more then this?
http://homesupport.cisco.com/en-us/wireless/linksys/E1000
Dec 22, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Computers & Internet Logo
387 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
