Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Piilips 55in i dont have the remote it came with how do i ajust color settings
    Genius:
  • 2,920 Answers
U may need to buy a universal remote
Posted on Sep 21, 2008
SOURCE:
Get my dish reciever, sony home theatre, and 55in sanyo tv to work together
If your TV and sound system both have a Digital Optical Out/In you can use a TOSLink cable (an optical cable) to connect your TV directly to your sound system, and remove the connection between the DISH receiver and the sound system. As long as your sound system is on the right input, all sound accompanying the picture on screen will go to your sound system. Most TVs also have an option to turn off the internal speakers, if not just reduce your volume all the way down to avoid that weird ghost sound effect. If you use your sound system all the time for volume, you can program the sound system to your DISH remote's AUX, and even set the remote so that it only sends volume and mute commands to the sound system (that way you don't have to dance between sat, tv, and aux all day, just leave it in sat mode).
To program your remote to the sound system, follow the instructions on the sheet you got with the remote (yeah, right like anyone kept that) http://www.mydish.com/support/remotecodes you can use that link to program your remote. You can also use the learning mode if your remote has a little glossy square on the top left side and you have the original remote to the sound system. (Learning mode can be gleaned from the remote manual Remote Control Manuals)
After programming the aux device, and verifying that it changes the volume up, down, and mute, THEN:
Hold AUX until light blinks 3 times, hit pound (#), Volume Up, 0 (Zero), pound (#), SAT, then test to make sure it goes up and down.
Sep 24, 2014 | DISH Network Televison & Video
Screen getting darker and color will not adjust
THIS LOT FAULT AJUSTMENT YOU ARE ELECTRONICS PERSON TAKE 25 W SOLDERING IRON RESOLDERING TO CRT NICK BORAD OR AJUST ON LOT, WATCH BELOW VIDEOS
NOTE:DONT TOUCH LOT ON SUPPLY
DONT TOUCH LOT&CRT LINKING PLACE WITH OR WITH OUT SUPPLY
SEE :LOT(LINE OUT PUT TARASFORMER) IMAGE ON GOOGLE
Mar 23, 2014 | Mitsubishi WS-65819 TV
Ajustment setting
It is because you picked up the 12V memory power wire from the keyed power. It has to connect to constant 12 volt source to hold memory settings.
Dec 21, 2013 | Sony Cdx-gt35u Car Audio Cd/mp3 Usb Aux...
I am a technicien, i 'll like to ajuste the convergence for tv sony kp-46wt500 ,but i dont have the code to go in the tv (service mode)
With set off and using the original Sony remote:
Display, 5, vol up, power
Buttons on the remote will let you cycle thru the menu to the convergence adjustment--do you know what buttons to use and what they do?
Mar 20, 2012 | Televison & Video
My alarm/horn wont stop going off. It starts going off at random times. It still rings while Im driving. I dont have my alarm remote because it broke. How do I fix it?
hi you will need to ajust the sencitivity of the alarm this has happened to me also with a little ajustment it will solve the problem
Mar 16, 2011 | Vehicle Parts & Accessories
I WENT TO MENU SETTINGS AND TRY TO AJUST THE COLORS OF THE TV AND I THINK I ACCIDENTLY PRESS THE WRONG BUTTON ON THE TV TO SOMETHING ELSE. , AND WHEN I TRY TO GO BACK TO MENU IT DIDNT LET ME SCROLL UP OR...
Can you give a model or a brand of TV?
From the information I have and the fact it won't turn on at all, the only thing I can suggest is unplugging it from anywhere to 5-15 seconds and trying again.
What it sounds like is you accidentally put the tv into Showroom Mode. That's the mode that TVs are in when you go to a store and they're on display. It's there so customers can't mess with the settings.
Feb 28, 2011 | Televison & Video
Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Dec 07, 2009 | Samsung HCN5529W 55" Rear Projection...
Tracking
From the MENU select SETTINGS and follow the guide from there
Sep 14, 2009 | Sanyo DP32746 32 in. LCD Television
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
