Question about Janome Mini Compact
Tension is too tight unable to loosen cotton breaks Maybe needs a service??
  • 415 Answers
Before you do anything else unthread and rethread the machine again. Sometimes the thread gets hooked on something or wrapped around and will cause it to break. Of course do check the tension again too. Is it breaking when you pull on it before it goes through the needle?
If it is breaking when sewing then it could be that the bobbin tension is too tight.
Posted on May 27, 2011
My trouble with Viking Emerald 122/118/116 sewing machine seems to be with the THREAD GUIDE....IS HOLDS THREAD SO TIGHT THE THREAD BREAKs CAN YOU HELP ME YHANK YOU
Is it a thread guide or the tension disk? If it's a thread guide, it probably has a burr or damage that is catching the thread--or is the thread perhaps wrapped around a guide? If it is the tension disk, it could have debris stuck in it, it is set too tight, or it may be damaged.. You can clean it by loosening the tension as much as possible, RAISE the presser foot, and dampen a piece of cotton perl thread with rubbing alcohol and then pull the thread DOWN through the tension mechanism a couple of times.
Remember to ALWAYS RAISE the presser foot when threading the top thread.
If the problem persists, you may need to have it serviced.
Nov 03, 2017 | Sewing Machines
Upper thread too tight and the control wheel for loosening upper thread is not much of help since it is set for 0 to 2 for sewing simplest things. How to fix it? Thread is constantly breaking off.
Totally remove the upper thread from the machine then rethread. When threading the top thread, ALWAYS RAISE the presser foot so the thread will seat properly in the tension disk. The thread is probably breaking because the tension is too tight. Try setting it at the midway point and then tweak it from there. Also check that the thread path is correct--incorrect threading could cause extra tension on the thread.
In case there is gunk build-up in the tension disk, you can moisten a piece of perl cotton thread with rubbing alcohol, loosen the tension disk all the way, Raise the presser foot and then, gently, pull the perl cotton Down through the tension disk a couple of times. (Always pull Down, Never Up!)
If you continue to have problems, you may need to take it for service.
Mar 18, 2017 | Sewing Machines
How do i stop the cotton breaking ?
could be the cotton is too old ( cotton has an additive in it to stop it unraveling and this additive deteriorates with age and weakens the cotton--makes it rough and so it will not slide easily through the eye )
go up an needle eye size
check that the thread is not jamming rather than between he tension plates
check that you have the needle in correctly ( groove in the needle facing the thread )
Dec 07, 2015 | Husqvarna Sewing Machines
Instructions for threading
search on Google make, model,manual or threading instructions
Dec 07, 2015 | Sewing Machines
It keeps braking the tread. I change needles and still break the tread.
Could be your tension is too tight. Try loosening the tension. Also, a different brand of thread may work better in your machine. Some machines just refuse to use certain brands of thread successfully. Also make sure the needle, thread, and fabric are compatible, ie is the thread too thick for the needle's eye?
Also, try rethreading your machine from the very beginning, BUT be sure to RAISE the presser foot when threading the upper thread. This allows the tension disks to release so the thread will seat properly. Consult your owner's manual to make sure you are threading everything in the proper order. There could also be gunk or lint stuck in the tension disks. You can dampen a piece of pearl cotton in rubbing alcohol, loosen the upper tension disk all the way, and then gently pull the pearl cotton down through the tension disk to remove whatever may not belong.
The tension should be correct when the upper thread and bobbin thread meet in the middle of the fabric. That being said, when you change fabric, you will probably need to readjust the tension for that project. Get comfortable adjusting the upper tension--it is part of successful sewing.
All About Needles
Nov 19, 2015 | Sewing Machines
I have a brother vx-1125 the cotton keeps snapping..but the tension is correct..please advise..
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Aug 17, 2012 | Janome Sewing Machines
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Sewing Machines
I'm in trouble deep-I was trying to fix an old
Good day!
Good day!
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
Thread jammimg on the underside when sewing
This is usually caused by the machine being out of sync. The first thing I would try is a brand new needle. Even a slightly bent needle can cause this problem. Make sure the needle is in correctly and tight. Next make sure you treaded the machine correctly, making sure that thread goes into the top tension properly. The top tension should be calibrated to be in the middle. I would slowly turn the handle making sure the stitch looks proper. From there try tightening or loosening the tension until the loops on the underside start to get smaller until they look tight but not too tight or you'll start breaking the top thread.
I would use a standard 14 needle with some standard medium weight cotton to calibrate the unit.
Hope this helps. Let me know your results
Aug 23, 2009 | Euro-Pro 416 Mechanical Sewing Machine
Janome Mini Compact Logo
46 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
