Question about Whirlpool Duet GHW9150P Front Load Washer
A10 Fault code appears on my front load Whirlpool washer. What does this mean?
jsrock516
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
the dr
  • 447 Answers
SOURCE: Whirlpool washer Cabrio WTW6600SB1
Its the Rotor Position Sensor very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
  • 36 Answers
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
take off the bottom kick panel locate the drain pump now there will still be water in the washer so take caution when following this procedure i use a shop vac and suck all the water out of the drain hose to prevent a mess then the frount of the drain pump will screw off check it for blockage or damaged impeller blades
Posted on Dec 28, 2007
SOURCE: LG WD-12331. Front load washer and dryer machine
since it is a washer-dryer, the lint trap is in line with the drain. you have to empty the drain basket. there's an access door on the bottom left, first take the little tube out and drain the remaining water, then open the large drain cap to the right and clean out the trap. once you're done put it all back together and it should work. you're supposed to do this every few months. It was too much for me to deal with so i ended up buying a separate dryer and just use the washer .
Posted on Aug 02, 2008
geemarie
  • 876 Answers
SOURCE: Whirlpool Front Loader Washer Model# WFW9600
This code is not on the list.
Try this:
Push cancel twice
Select drain and spin
Select your cycle and push start.
If this does not clear the code, you will need a service call.
Before you do that I am wondering-Are you using an HE detergent and in small amounts? Are you loading the washer evenly- for example towels with towels lingerie with lingerie and jeans with jeans. Front loaders are very sensitive to how they are loaded. Check everything you can:
Turn off the washer and unplug it. Grab some old towels and a bucket.
Check the drain hose- is it twisted, squished or plugged ( you can turn off the washer unplug it and remove the drain hose to see if it is clogged.) While you are back there check the incoming water hoses are they twisted? Unscrew them from the washer and make sure the little filters at the ends of the hoses are not plugged, so that water is coming in freely. Make sure water valves are turned all the way on.
When you are back in front examine the door seal. Is it in good condition? Give the tub a spin with your hand. Does it spin freely and does it feel secure?
Check your dispensers. Are they clean and empty? if they are not try running an empty short cycle with just a little Hot water in the liquid dispensers to see if they are plugged.
Okay. Good luck to you. I hope this can be solved without a service call.
thank YOu for using FixYA Ratings are always appreciated.
Posted on Aug 24, 2008
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Whirlpool awm 8125 fault code F09 followed by FA
    The drain pump runs constantly in an effort to drain the water. Unplug the washer and, if the washer is overfilled, check the water inlet valve assembly for proper shut-off of water flow. If the water inlet valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water-level pressure switch.
    Dec 16, 2013 | Whirlpool AWM8143 Front Load Washer
    Whirlpool WFW9200SQA10 Front Load Washer displays F30 code. What does F30 mean? Thanks
    "F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
    1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
    Thank you !!
    Jun 20, 2010 | Whirlpool WFW9200S Front Load Washer
    Washer displaying a fault code.
    check your manual. it will tell you what it means and what to do
    Apr 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
    Whirlpool Duet Washer error code A10
    Motor Control Unit (MCU)
    Heat Sink Thermal Trip
    If the thermal protector on the MCU heat sink gets too hot, it will open
    the thermal protector on the heat sink which will stop motor functions
    and an “F/10” will be displayed.
    1. Check for proper installation, verify the unit is not located
    near a source of heat and has proper ventilation.
    2. Unplug washer or disconnect power.
    3. Check wire harness connections to the MCU, the motor,
    4. Check the drive system for any worn or failed components.
    5. Plug in washer or reconnect power.
    6. Check the MCU by looking for operations of the drive motor.
    7. Check the drive motor for powered rotations.
    Feb 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Duet washer code f 33? What does it mean?
    the fault code indicates that your main data cable from the controller to the motor has miss-comunicated: unplug the washer wait about 30 minutes then plug it back in and, let me know if the code clears
    May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    On whirlpool duet ,am getting fault code f21 in wash cycle.
    Foreign objects in the prepump
    remove access panel in front remove round plastic plug clear objects have towels ready
    Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duetsport front load washer
    Check the following link:
    http://fixitnow.com/wp/2008/09/27/whirlpool-duet-washer-with-f-21-fault-code/
    Nov 08, 2008 | Whirlpool AWM5145/2 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    2,648 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
