Question about Murray Garden
Murray Ultra 46in starter solenoid was clicking on start attempt, no engine turnover. I charged the battery, checked the fuse and finally replaced both. Then I replaced the rusted-on solenoid. By memory and google searches I'm confident that I have the wiring correct. The clip on the black wire to the male connector partially broke but I have used electrical tape. I still have no reaction upon attempting to start. Ideas? Can't tell if a wiring problem or other?
  • 3 more comments
  • russschoenke May 28, 2011
    Thanks Paul4265. Yes, replacing the black wire was an obvious next step. In addition I also replaced the fuse harness as it was not holding the fuse in very securely and the metal connectors were beginning to crumble. New battery is fully charged. I still have no turnover. No sounds, no lights. Battery cables are looking new. Seat cutoff Switch looks fine and was working recently before my troubles began at the solenoid. I'm trying to come up with my next plan of action.
  • russschoenke May 29, 2011
    I'm looking for further advice. Meanwhile I'm replacing the spark plugs.
    Joe, not sure if you if you can see my last update. I've already replaced that wire and male connector.
    Thanks.
    I need further ideas. Thanks.
  • russschoenke May 30, 2011
    Honestly, I'm not sure how to check the voltage at the seat switch. I have a hand held battery tester though. My solenoid is a three Connector with green ground wire securely attached at solenoid flange /frame. How do I test voltage there? All wires appear secure. So I'm hoping that your approach of testing each area provides a clue. Thanks.
  • Murray Master
  • 2,239 Answers
If the solinoid is clicking it is tryiny to work, make sure you have a good earth to the solinoid, and a good earth to and from the battary, make sure you have connected the battary the correct way round, you can try carefully putting a suitable jump leed between the two high tention conections on the solinoid, if the engine still does not crank it could be an issue with the starter motor itself, turn the engine backwards by hand to make sure the the starter gear is not trapped in the flywheel ring gear.
Posted on May 30, 2011
  • 5,370 Answers
Check voltage and connections at seat switch also.If there is any loose connection or shorted wire it will cause the problem.by pass seat switch and connect wire directly and see if that helps.-------- also for starter solenoid problem, check voltage at starter solenoid, there should be 12 volts an also check the starter ground wire connections.Is it mounted to the frame.-------- This will help.Thanks.Helpmech.
Posted on May 29, 2011
  • raj somaiya May 30, 2011
    The seat switch is under the seat, when you sit on the seat the seat switch gets pressed and completes the circuit and mower starts.But if this seat switch is not getting connected properly then it will not let the mower to start or some times mower will start and stop and repeat the same cycle.Just to test if its seat switch issue.Remove the seat switch connections and connect jumper wire between the seat switch wires then try to start.If the mower starts and runs fine, then its seat switch issue.If not then its starter connections issue.Re check the starter solenoid connections, remove and reconnect also check voltage at ground green wire. if it shows voltage then its getting short, if no voltage that means its proper connected.----------
  • 10,865 Answers
Hello russ... i suspect that the parts that you taped together are not a good enough connection to make everything work properly. replace those broken components and you should be good to go. J.
  • 592 Answers
Hi, Russ.
First, I would replace the entire black wire that has the broken connector on it.
If it has even a partial break in the internal wires, then it could restrict the power supply to the point where it won't start.
Next, at the point where the solenoid attaches and it was rusted, you need to scrape every bit of the rust away, as some of the solenoids utilize the frame structure as the common ground, so if it's not getting a good connection due to rust build up, then it can prevent proper function as well.
Now, you said you bought a new battery, so I would check to make sure that it is fully charged.
Sometimes, the manufacturer put just enough charge in it so that it will light a lightbulb, and that's about it.
The next thing after that you will want to check is the wires for the starter switch, see if there is any corrosion or rusting going on there as well.
As you can see, rust, and good contacts play a major role in proper functioning of the mower.
I wouldn't have thought that it would make that much difference, until my old Bolen's riding mower started acting strange.
Turned out, the back of the ignition switch was so corroded, that it looked like it was ready to fall apart.
I know this was several items that I listed for you to check, and I'm sure I'm forgetting some, but it gives you a major place to start and see if the problem lies with those areas.
I hope this helps you out, and have a good day.
Posted on May 27, 2011
  • Paul Pope
    Paul Pope May 29, 2011
    Hi, Russ.
    I have a couple more things that might be causing the mower to not start.
    First, although the seat safety switch might be o.k., I would still try to send some voltage into it, and then manipulate the switch to ensure that the power is indeed making all the way through the switch.
    Another thing that might cause it is the wires going both to the seat switch, and from the switch to the solenoid and starter.
    It almost always turns out to be something little when a mower fails to start.
    I had one that wouldn't start unless the headlights were on high beam!
    Weird, I know, but I'm just saying that the strangest things can cause a ignition fault.
    Maybe you'll find out that the seat switch is in fact defective, if so then at least that will be a inexpensive repair.
    Good luck to you, and I hope you can get it going.
Why won t my car turnover
  • Okay, a clicking sound is the solenoid engaging the starter drive gear but the starting motor is not turning over. First possible is low battery. Second is bad or dirty connection, usually battery terminal. Good enough to energize solenoid but not enough amps to spin starter. Third is a bad starter motor, usually a brush corroded, worn or stuck.
  • Lift the hood and look at the battery terminals. if they are clean and tight, check the battery for charge. I usually hook a booster on and try cranking the engine over. ZIf it works, charge or replace the battery.
  • If it didn't crank, Take a jumper cable and connect the one end to the battery positive. Touch the other end to the starter motor terminal. Motor should turn over, if not, replace the starter.
Apr 01, 2014 | 1993 Ford Explorer Limited
After drving around and after the engine gets hot, the engine wont turn over, i get a click but nothing else. only after numerous attempts to start the engine,does it finally turn over, i have replaced...
check the battery cables at the battery and the starter. also check the engine ground on the transmission. most likely you have a bad starter solenoid even though you have replaced the starter before.
Aug 07, 2011 | 1989 Toyota Camry
I own a 2000 pontiac bonneville ssei that wont start, i thought it may be the battery but would not take a jump and all lights and heater fan are working at full capacity. I did the key trick 10 min- 3...
when the lights go out when the key is in the run position , that indicates loose battery terminals, battery posts and terminals are black and not shiny clean and bad ground wire or just a bad battery
have it load tested
May 26, 2017 | 2000 Pontiac Bonneville
Battery is charged. Went to start car at the end of the day, and there is a mechanical clicking sound (all dash indicators light) but the starter motor won't engage, and car won't turnover. Bad...
Do this to check if it's a bad battery, turn head light's on and try to start it, if head light go to dim or off, bad battery not holding a charge, if light stay on ok, then this will take two people tap on the starter kinda hard with a hammer or something you can reach it with while some one hold's to key to start, if it start's bad starter or trys to turn engine replace it.
Jun 29, 2010 | 2001 Mercury Sable
My 1994 Yamaha Virago won't start after a several month deployment/winter storage. I trickle charged the battery. All electricals seem to be working fine, but the starter solenoid just clicks rapidly with...
Check condition of wire and the ends, to the starter and solenoid .read dc volts at bettery to make sure there is 12 or 13 volts any less needs new bettery,or a stronger charge perhaps.
Mar 25, 2010 | 1997 Suzuki TL 1000 S
My 2000 gmc truck will not start. New starter,
I assume that you mean that the starter will not run. Do you hear the starter solenoid operate (click) when attempting to start? If so, using either a voltmeter or test light, look for 12 volt power at the battery side of the solenoid. If none or it disappears when the starter attempt is made, check the cables from the battery for badly corroded ends. Also, check the grounding cable running from the frame/body over to the engine block for damage. If you hear no click from the solenoid, look for power which should appear at the small terminal of the solenoid when starting. If you get power, replace the solenoid. If no power, then look for a blown fuse, bad relay, bad ignition switch, or any damaged wiring. Make sure the new battery is fully charged. Hope some of this helps!
Dec 14, 2009 | 2000 GMC Sierra
Lights come on but it won't start, just makes clicking noise
Either the battery is low (the lights will still come on) or the starter solenoid needs service. According to your description, the battery may be too weak to turn over the engine. Have the battery charged. If the battery is OK the solenoid should be checked. This can be done by your local parts store.
If the battery was low, you might want to invest in a battery trickle charger to recharge the battery in between the driving of the vehicle.
Hope this helps.
Dec 01, 2009 | 2005 GMC Sierra
Murray 18hp 42 deck wont start
Hi.
The best advice here is to put your battery on charge, and, while it is charging, remove each connection, and clean the terminals back to "bright and shiney". The clicking noise is probably the solenoid trying to pull in to provide power to the starter. There also sounds like the comnnection to the starter needs to be removed and cleaned. If this connection is dirty or loose, it can arc and smoke without cranking. Also, if the terminals at your solenoid are corroded, the motor cannot recharge the battery on the run, and loss of power to the battery will result. Clean your connections, and try again!
This should correct your issues. In extreme conditions, it may be necessary to replace your wire from the solenoid to the starter, if it is significantly deteriorated, but I'd clean it all up first.
Best regards, --W/D--
Aug 11, 2009 | Briggs & Stratton Garden
Turnover problem with toro 16-42z riding mower
A fully charged battery should read a minimum of 12.65, if it does not and connections and grounds are dirty then that's your problem. Start with a none fully charged battery.If you can bypass the solenoid and start it then the culprit is the solenoid. Good luck. donnyb60
Mar 25, 2009 | Garden
Garden Logo
177 people viewed this question
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
