Question about Mtd Garden
When i try pull to start the lawn mower, it does not start. but i see some gas spill out from the muffuler,what is wrong?
    Novelist:
    Champion:
  • 222 Answers
You have not provided much info to go on, but you may have an exhaust valve that is stuck in the open position. In this case, the fuel/air mixture that is going into the cylinder would be blown out thru the exhaust valve by the piston and come out through the muffler. Unless you are engine-savvy, this repair is better left to a professional. Hope this helps. Best of luck.
James
Posted on May 27, 2011
Have a Murray push mower..changed spark plug, gas, and put in oil ...still can't get it to start ...what else could be wrong
try dribbling a ittle gas into carb then pulling rope .this works many times for the first start of the season.
Apr 11, 2015 | Garden
What is wrong when oil mix with gas and the riding lawn mower will not start?
Riding mowers are usually straight gas, not mixed. If you accidentally put mixed gas in it the carb, plugs, and engine may be gummmed up. Clean, flush, start with fresh gas, and you should be OK
Mar 08, 2015 | Garden
I have Gas in my oil sump and sprays mixture out exhust when trying to start mower
what has happened is the rubber seal on the needle and seat has dried out and fuel is leaking passed then the carb overfills and then the gas flows into the cylinder and crankcase
Sep 03, 2012 | Craftsman Garden
Toro recycler lawn mower
if old gas was left in the engine a good carb cleaning will need to be done
May 11, 2012 | Toro Power Lawn Mower
I have a Poulan Pro 650 model. I need to flush the fuel line because I think the gas I put in it is bad. I no longer have the manual so I don't have any instructions. Does anyone out there have any...
First step is to take the gas cap off and tip the mower to pour the old gas out. Leave the cap off for awhile and let the rest of the gas evaporate. After you have handled this, pull out the spark plug and pull the started a few times. This will push whatever gas is left in the carb and lines into the cylinder where it can evaporate or spill out of the spark plug hole.
Jun 02, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Mower tries to crank but want start up? Replaced sparkplug , oil filter has gas
Pull the spark plug and squirt alittle bit of gas or starting fluid directly into the cylinde rand reinstall plug . It will fire I promise. Repeat if necessary untill it stays running. Hope this helps
Nov 04, 2010 | Craftsman 21 Hp 42" Lawn Tractor Riding...
The pull cord on the mower is frozen after several times of pulling it.
The drive shaft might need to be lubricated. If the shaft won't turn, you won't be able to pull the cord.
Try turning the mower on its side (making sure all of the caps are on so you don't spill gas or oil) and lubricating the drive shaft with WD-40 or 3-in-1 (or another similar lubricating oil). Coat the shaft where it disappears into the housing of the mower, and turn the blade by hand -- carefully, so you don't cut yourself -- to work the oil in. After turning the blade a few times, add some more oil to the shaft and turn it more. It should become easier to turn. Then turn the mower back onto its wheels and try the pull cord... it should pull easily now.
Oct 16, 2010 | Husqvarna 21" Walk Behind Lawn Mower HVL...
Craftsman 5HP Mower does not start
try changing your primer bulb
May 31, 2009 | Craftsman Garden
Garden Logo
330 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
