Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
My trimmers contacts are always closed so my trimmer wont start, how do i fix this
    President:
  • Poulan Master
  • 1,545 Answers
Use a standard sized business card. Place it between the legs on the ignition module and the flywheel. Loosen the screws on the module. Let the magnets in the flywheel (you can see them) draw the legs in. Your "air-gap" will be set and the setting is about .010". You will now have spark and it may just run!
Posted on May 27, 2011
IT STARTS BUT TRIMMER PART WONT TURN
Disconnect the two halves of the shaft. It should be pretty easy. Inspect the drive cable to make sure it hasnt snapped. Also make sure the cable is inserted into the female half. Its a square shaped cable that spins and drives the string trimmer head.
Jul 24, 2016 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
Does trimmer head spin at idle
this is a hard question ,ill start with the text book answer , NO the idle should be low enough to disengage the clutch and remove power from head . but in reality this always is not possible , me I judge a clutch and engine idle % to be working correct if I can put cutting head on ground and not have it take off with throttle closed off
May 26, 2015 | Craftsman WeedWacker Gas Trimmer 25cc...
Why wont my craftsman 25cc start
99% of the time its a carb or fuel problem. Always run premium fuel and store the machine in a cool place less than 100 F
Might can put a drop or two of fuel down the carb and revive.
Jul 18, 2014 | Craftsman 25cc Gas Line Trimmer
Stilh trimmer wont start changed plug still doesnt even fire
Please make sure you have no leaks on the carburetor, if it has not been turned om for a long time, prime the engine for cold start. Here is how to do this.
Clug exhaust pipe while you crank it up.
Pump the bubble filled with gas closed to the carburator.
Thanks,
Jul 17, 2011 | Garden
Trimmer starts but the spool wont turn anymore
you're trimmer could have one of two problems, One, if it has a clutch on the engine,( the way you would tell is if it doesn't spin when it idles. it has a clutch) Two, your trimmer would spin all the time, they use round flexable cables stamped square on both ends, which fit into square sockets one at the engine one at the trimmer head, so you're problem is either a worn out clutch, or, the cable is broken, or, one maybe both sockets have become rounded out. I hope this helps you out. Bob
Jul 31, 2010 | Poulan Garden
Starts easy and idles well with choke on full. Dies in run
Open the air adjustment screw a bit more. There's usually plastic piece that stops you from opening it up. I always break off the plastic.(damn engineers) It's not getting enough gas.
Aug 14, 2009 | Craftsman 25cc Gas Line Trimmer
Wont start
could be a fouled plug,bad coil,or contacts on flywheel rusty
Aug 04, 2009 | Craftsman 25cc Gas Line Trimmer
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
79 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
