When I turn the TV on I can see the picture only a few seconds and then appears a blue box that says 18G1W016 FACTORY. I can not see more the picture. The same happens if I put a DVD, the movie is playing but the blue box can not be removed. I can not watch nothing.
  • 517 Answers
Good day!
I think is on the set-up please try to go to the menu using remote control then go to settings and find the default set-up.
Thank you
Posted on May 27, 2011
My 32 inch element tv when i push the power button its red then turns blue but no picture
How old is it? TRY this.. Hold down the menu button on the top or side of your TV for at least 10-15 seconds. An on screen menu will appear asking you to enter the time, date and location settings. Follow the onscreen instrucitons, and once completed your TV will reset to factory settings.
Feb 02, 2017 | Element Televison & Video
My philips hd tv does not have a picture . only
Do the channel controls work? If not, then try going into the TV's menu and find the factory default reset function. If that solves the issue, you may have to do that every time you turn your TV on.
Just as with almost every other issue, I suggest you get in touch with the manufacturer for proper assistance.
Jun 03, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
Mitsubishi 50 real projection blue screen
Turners are Bad Signal Board Call Encompass Parts 1-800-638-3328 or your nearest Repair Shop.
Dec 31, 2009 | Televison & Video
LCD TV has power but no picture or audio
one or 2 blown capacitors in the power supply
you will see the dome tops where they vented
Sep 16, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a flat screan and when i turn it on i get
Do you have cable or are you getting channels over the air? Is your TV digital ready? Do you have a digital converter?
If there is an option for setting the formatting to NTSC or PAL, check that you have the correct one selected.
PAL is European and NTSC is North American.
Aug 17, 2009 | Westinghouse Electric SK-32H570D 32 in....
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
No video on our tv
I found in the manual on page 13 bottom, that if you PRESS STOP buttom for 5 seconds of your remote controller then you can see the picture on the interlaced mode again on your TV.
Otherwise you have to connect you DVD to a unit that has progresiv scan, such as an HDTV, some computers if they have an input or to a projector .
I connected my DVD to a projector thru the VIDEO output and put eveything back to normal, and it is working fine now.
System Reset
Open CD disk tray. Press stop key and hold for 15 seconds, screen will appear.
Apr 01, 2009 | Akai DVPS760 DVD Player
Black box in middle of screen
It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
Mar 07, 2009 | Panasonic PV-C1322 13 in. TV/VCR Combo
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Tv won't stay on
it is a brandnew tv, so expected that it is under warranty,, it best for you to return where you bought so the warraty will not void. Big possible of factory deffect.
Dec 26, 2007 | RCA 20F420T 20" TV
Televison & Video Logo
Top Televison & Video Experts
