Question about Janome Memory Craft 4000 Sewing Machine
Quilting on Janome MC 4000
I want to quilt and have lost my user's manual. Is there a way to disengage the feed dog so that I can quilt without having to twist the whole quilt all over the place? Also, if this is possible, what presser foot should I use.
Thanks,
Cindy Davis
Woodbridge, VA
I have a MC4000 and a manual. To raise or drop the feed dog, remove the accessory box and feel at the back of the free arm there is a lever that will slide left or right to raise or lower the feed dog. I am not a quilter, but the manual says to use foot A (zigzag foot) and accessory L (quilter) which appears to be a guide. Cheers, Deb, Townsville, Australia
Posted on Nov 03, 2008
SOURCE:
Fabric does not move under pressure foot
Look for a lever under the plate that disengages the feed dogs for free form quilting. More detail would help. My wife is a quilter.
Mar 08, 2018 | Sewing Machines
When quilting more than 2 fabrics, the feed dogs won't push the thicker fabric through. What else can I do?
So you are quilting but not free motion quilting... Generally, a walking foot is used when just doing straight stitch quilting. It has feet that actually walk at the same time the feed dogs are pulling.
Aug 03, 2017 | Sewing Machines
How do I set up my Janome 1600p-qc for free motion quilting?
You will need a darning foot or free motion quilting foot for your machine (these feet are shorter than the regular feet which allows space between the foot and the needle plate to manually manipulate your fabric). Then drop the feed dogs and, if your machine does not have that capability, there should be a cover plate included with your machine that snaps over the feed dogs. Install a brand new needle in your machine, set it for a straight stitch, and test the stitch. Sometimes, the upper tension needs to be loosened a bit so the bobbin thread does not poke through the top of the fabric.
Then...practice, practice, practice...
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting Beginner Tutorial 1 of 4
FWIW, I've found it helpful to use a "Supreme Slider" on the base of my machine. It is slick and allows the fabric to move easily. Special gloves are helpful too because your hand will become dry and begin to slip on the fabric. Using cheap rubber gardening gloves works for some people.
supreme slider Google Search
quilt gloves Google Search
Feb 11, 2017 | Janome Sewing Machines
How do I drop feed dogs on jem silver 662?
Here's a manual:
Instruction Manual Janome Jem Silver 662
The following is for a 660, but it doesn't mention anything about darning or free motion quilting:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwih_NGBzpjRAhXKh1QKHbKIAvwQFggoMAI&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fcompact-models%2Finst-book-jem-gold-660.pdf&usg=AFQjCNEwCPZs5n8s4wdgIHMGHbN-GvDe-w
You can also contact a Janome dealer. If the machine does not drop the feed dogs, there should be a special plate accessory to cover them in order to do darning or free motion quilting.
Perhaps this is the accessory you need:
http://www.sewingpartsonline.com/cover-plate-elna-janome-necchi-825018035.aspx
https://tv-sewingcenter.com/products/janome-quilting-attachment-kit-for-jem-series
Dec 28, 2016 | Sewing Machines
How do I drop the feed dogs for quilting on my Brother XL 4011 sewing machine
It should be included in the owner's manual. (An internet search did not turn up a manual for your machine, but a model close to your machine may operate very similarly.) You can also contact Brother Support.
This may help:
Frequently Asked Questions
The other possibility is that the feed dogs on your model do not actually drop. There may be an accessory (darning plate) in your kit that covers the feed dogs during darning or free motion quilting. (Shown on page 38 of the following manual):
... Brother XL 4011 manual Google Search
Jun 22, 2016 | Brother Sewing Machines
I need instruction manual for Magnolia 7318
Janome Magnolia 7318 (Sewing-Quilting Machine) user manual, guides and product documentations.
http://janome.imvoi.com/sewing-quilting-machine/magnolia-7318.html
Look under available documents and click on "Janome Magnolia 7318 User Manual".
This opens the user manual in PDF format.
You can save the PDF to your local computer to refer to any time without going online.
Dec 03, 2011 | Janome Magnolia 7318 Sewing Machine
Where is the feed dogs botton on my brother xl3010. I need to drop them for quilting and can't fine the botton.Lost my book .thank you
The User Guide suggests there is a different Needleplate (must be thicker than standard) used for darning, free motion quilting etc.
Look HERE for a replacement manual for your Brother XL 3010
Bargain Box
Feb 12, 2011 | Brother Sewing Machines
Raising feed dogs
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link to them:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Aug 14, 2008 | Janome Memory Craft 10000
Frame quilting with janome 1600 db
am I right that the feed dogs do not drop on this machine?
Yes, this is correct....but you have to change the needle plate to a thicker one, so the feed dogs will be below the needle plate.
Feb 13, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
632 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
