Question about Garmin FISHFINDER 300C NIC ()
The boat has been idle for a while and when I pressed the fishfinder unit on the "on" button it showed the screen. When I pressed the "select" button the unit switched off. after reading information that the fishfinder sensor should be submerged, I took the boat into the water and all attempts to restart the unit have failed. I have out of water checked the unit again and pressing the on button the screen has come on. I did not press any other buttons and switched the unit off and awaiting your advice to the problem.
    Guru:
  • 257 Answers
Hello Alexpreerado,
I understand that you are having a problem with your Garmin fishfinder 300C. When in the water the unit is not turning on, however when out of the water the unit will turn on. I want to see if the unit will work in simulation mode.
To do this you will need to follow these directions:
When powered on select CONFIGURE, SYSTEM, SIMULATOR, ON.
If the simulator works then you know that the unit is working. Then go back thru the same way and turn the simulator back off,
Your unit is equipped with a self diagnostic unit that if there is a problem it should power and give you a fault reading. If the unit is not powering on while in the water you are loosing power to the unit. Put the boat back in the water and check the voltage going in to the unit. You may find that you have a short while the boat is in the water.
Post back with what you find from the above possible solution to the problem. And I will give you some more possible problems and solution to your problem.
Thank you for choosing FIxYa.com
Justinbur167
Posted on May 27, 2011
Lowrance hds 5
I would imagine it might have something to do with water turbulance? Do you have a sensor thats located at the bottom of the boat somewhere? In my grandpas boat, the sensor is at the rear bottom near the hole where you can drain the water, if your going very fast it doesnt work very well, slow or stopped and it works fine. If you have that type of sensor make sure whatever holds it is tight so the sensor cant move around.
either that or you got some funky wiring issue lol
Nov 01, 2013 | Lowrance Hds-5 GPS Receiver
Eagle Fisheasy No screen display and only beeps
You could have blown the transducer.....it is supposed to be in water before you turn it on. A 5 gal. bucket inside the boat would be fine for when out the water. Put the transducer in the 5gal bucket with water and try again. You may have to get another. sorry.
Dec 20, 2009 | Eagle Fisheasy 250ds Fishfinder
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
Lowrance 330c screen says '' boot failed''
Try a hard reset:
1. Turn the LMS-330 off
2. Press and hold the ZIN, ZOUT, and PWR buttons
3. Release the three buttons once you see the "warning, do not rely..." message appear
If you get that far, the problem is solved. If you get boot failed again, try installing the latest update which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If you still get boot failed, you will need to get the LMS-330 repaired/replaced. You can contact Lowrance support at 800-324-1356 or email them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
Mar 22, 2009 | Lowrance LMS-330C GPS Receiver
Navman 4500 FishFinder
Was there ever a solution to the Fishfinder 4500 going blank but still powered on????
Jul 19, 2008 | GPS
RAYMARINE
With the charts page up, start by hitting the find ship softkey at the bottom of the screen.If that find the boat on the chart all is good.If not you need to check you have a GPS fix. Go to GPS screen and see you are seeing satalites.
If all is good when you hit find ship and the boat disappears again from chart while underway you will need to go into the chart setup menu and see if the screen amplifier is turned off. If off turn on.This is first place to start. Hope that helps
Jul 13, 2008 | Raymarine A65 Combo GPS...
Garmin FISHFINDER 300C NIC () Logo
282 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
