Question about Hamilton Beach Steam Excel 14770 Iron
I purchased a lumina steam mop but it had no instructions in the box, having trouble getting the handle to go in? is it possible to get these insturction on the net?
Wet steam coming out of iron
You have to take part the iron by unscrewing the three bolts on the side handle with a small phillips driver. Then loose the allen screw on one side of the black thermostat wheel to unloosen it. Then take out the two bolt plastic protectors under the handle and unscrew the two allen bolts, carefully separate the top from the botton of the iron, carefully not to pry loose the cables from the top to the hot shoe.
On the back you will see a small white square box, that is the thermostat, which has a button on top, all you need to do is to push it in. This will make the iron heat up unless you have a thermostat failure (Black wheel with temperature indicators), which you will need to order the part and change it.
Mar 07, 2013 | Reliable i30/120V Professional Steam Iron...
Sunbeam steam valet instructions
How to fill your Sunbeam Steam Valet
Here is how you fill your Steam Valet. Press the small button on the back of the handle and pull bottom of handle apart from the top half of steam valet. Then take off the white cap on the inside of the handle and fill with water to top. Place cap back onto the opening and slide handle back and click in place. Plug in and you're ready to steam within a few minutes. If it spits out water let heat up a little longer if that doesn't stop it then tie a thin cloth over the top part where steam comes out to keep the water from spitting out onto your fabric. Hope these instructions are clear enough. More questions about this iron go to www.manualslib.com.
Feb 29, 2012 | Sunbeam Irons
Users instructions elitech 2000w steam iron
alas we've had the same problem since day one, just opened it up, must be the boiler unit leaking at the start to emit the steam so the handle gets hot and now the seal is totally gone it will just leak when the water gets too hot
Dec 12, 2011 | Irons
We own a SmartLiving Steam Mop, and have really enjoyed it. It suddenly quit steaming. We tried putting vinegar through it in case it was hard water deposits, but no luck. Any siggestions?
yep i have one,,,,,dont use vinegar,,,thats good on chips? no good in steam mops!
go get yourself some kettel cleaner ,,,the stuff for cleaning the lime scale off the inside of your kettel,,,,mix it up in a jug with warm water,,,,and tip that in your steamer,,,dont breath the fumes?
this will clean out any lime scale for you,,,next time fill it with rain water,,,,there is no lime scale in rain water?
Nov 27, 2010 | Hamilton Beach Steam Excel 14770 Iron
Instructions for calc n clean HAVE TODAY
Hi
I too had the same problem. I emailed Bosch (via their website and gave them the model number and they have emailed the instructions.
This should have been with the iron in the first place!
Aug 09, 2010 | Bosch Irons
No steam. I pressed the steam button on the underside of iron handle and no staem.
There 's a leaked capacitor in the circuit board. You just have to replace it and it works again.
Please visit the following page for detailed instructions:
http://thechipfreak.blogspot.com
Jan 15, 2010 | Rowenta DG5030 Iron
Instructions for use DiLonghi StiroMeglio compact iron (steam boiler Iron)
Is a long story but i make short.Don`t be afraid to leave your iron on.Is common to water tank iron to get working in more then 5-10 minutes.That machine are really safe since they do have more then 1 thermostat to control the water pressure.
How they work is pretty easy.The boil the water to a certan temperature and you know after certan F. the water become steam generatin pressure and steam.The thermostat control the heater and the electroswitch release the steam
If your in not making any steam after 5-10 minutes make sure you hear the electroswitch working.Sometimes they get cloght and even if the boil is under the pressure you can not get any steam at all
Good Luck
Jun 10, 2008 | Irons
HINARI LIFESTYLE STEAM PRESS
The RED button is located on the pull down handle.
Sep 22, 2007 | Irons
Hamilton Beach Steam Excel 14770 Iron Logo
146 people viewed this question
Top Hamilton Beach Irons Experts
Jim Thurston
Andrew Taylor
Andrew Taylor
richie46
Are you a Hamilton Beach Iron Expert? Answer questions, earn points and help others
