Question about Weber Genesis Silver C Grill
I have an older Weber. Where do I find the model # and can I just replace the little ignition box and then it will heat properly?
Under the control panel, to the right of the cooking box is a sticker with model numbers, serial numbers, BTU rating, etc. It is not easy to find or read. I used a flashlight and read the numbers out loud for someone to write them down. The first 2 letters of the serial number are the date code.
Posted on Jun 14, 2011
Weber grills manuals
Link to Weber manual download.
Note that there is more than one search option,serial #, Model #,
Weber com Support Manuals
Aug 16, 2014 | Weber Genesis Silver B Grill
Had trouble lighting weber Q, replaced regulator still will not light with igniter button, had plenty of spark . It will light manually with grill lighter but will have a small back blow of flames. Tired...
Are you using the valve-regulator or a conversion hose to a 20lb cylinder? a gas problem is different from an ignition problem. If an ignition issue the piezo module on that model has to have a good ground connection because cast aluminum will not ground at the electrode. make sure wires are tight and secure. Also check the "gap" at the tip of the electrode and adjust for strong blue spark. Most barbecues need the electrode gap adjusted when first installed. if an older model dirt and grease will interrupt the spark so make sure the tip of the electrode and area around it is clean -- burner and collector.
Nov 02, 2013 | Weber Q100 Grill
Weber q bbq
What is the model number? Here is a link to webers website http://www.weber.com this might make it a little faster for you to get your information.
Apr 28, 2013 | Grilling
I have a full tank of propane - grill will not ignite. I have a weber silver model
Hi, Check the igniter and also the gas nozzle that it is not plugged with grease. Clean up and try again. Make sure that igniter is working properly. Replace if nescessary.
Jul 09, 2011 | Weber Genesis Silver B Grill
The igniter box inside the grill is rusting and disintegrating. I bought the Weber igniter kit at Home Depot, but it has a red push-button, and I can't see how to begin replacing the igniter under ...
I have provided 2 links for you. One is the Assembly Manual for the Genesis B 330
and the other is the Owners Manual. Both should prove invaluable to you, in replacing the Ignitor Button. You can download and print each manual for future reference.
Assembly Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/AssemblyInstructions/Genesis_310320330_LPng_AssemblyInstrctns_56507_022811.pdf
Owner's Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/OwnersGuides/Genesis_320330_LP_OwnersGuide_56508_111010.pdf
Hope this is some help to you. Please let me know. Thanks & Happy Grilling!!
Jun 17, 2011 | Weber Genesis Silver B Grill
Replacing the crossover ignition system in my weber genesis silver b grill. it has a propane tank. the small metal cover over the spark ignitor has rusted out.
What you're referring to is called a Collection Box. It traps gas so it will ignite. You can purchase a new one directly from Weber or from Appliance Factory Parts http://www.appliancefactoryparts.com/
Hope this helps you get the part you need. Happy Grilling!!
May 19, 2011 | Weber Genesis Silver B Grill
Q220 very little heat
Buy the older weber "go anywhere" grill
Apr 13, 2011 | Weber Baby Q Grill
My weber spirit 310 igniter will not work. It does not click or make a spark. I have changed the battery. I did notice that the battery chamber was very corroded so I cleaned it out but still no click....
I suspect that the corrosion you found has taken it's toll. You will need to replace the the ignitor box.
if it's still under warranty, Weber may cover it. Either way, you can get the part from Weber on line. Make sure you have your Model #, Serial # of the Grill and the date and proof of purchase.
Feb 13, 2011 | Weber Spirit? E-310
My grill became hard to light & now will not light. I took it apart and cleaned it & noticed that the box around the igniter is all coroded away. How does this get fixed?
In the case of your grill's ignitor control box, it will have to be replaced. You can order one online. directly from Weber. Just be sure that you have the Model # & Serial # available. It's an easy replacement to accomplish. The new ignitor control box will come with the instructions or you can find them in your Owners Manual.
Happy Grilling!
Jan 23, 2011 | Weber Genesis Silver B Grill
Weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
May 26, 2009 | Weber Q Grill
Weber Genesis Silver C Grill Logo
183 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
