After installing a sata drive with xp home i took my old hhd and put it on the cable with another hhd on the same cable . Now mthe primary hd 0 and 1 are not found and f1 to continue then it will load x why? how do i stop that? And the computer recognizes the hhd2 hhd as a cd rom drive
  • kkwallace01 May 29, 2011
    I have a optiplex gs 270. The bios is not recognizing my 2 other drives the pin s on the cable are stock and the sata drive is the os. It has just a red cable that goes into one of two slots that are for ata on the M.B. My hardware manager will not list the 2 other hhd's and I went and took a sd card reader out of another computer and it is listed as a standard disk drive. There are four slots in the card reader. Is is a Usb device. I think I have both hhd's to cable select but I will try doing primary then slave? Or is the ata drive primary then I go slave then slave agian?
    Brigadier General:
  • 10,406 Answers
First, do you have a 40-wire or an 80-wire parallel-ATA ribbon-cable?
If you have the 40-wire cable, you need to set the jumpers on both of the old drives.
Set one disk-drive to 'master' (maybe also add 'with slave present').
Set one disk-drive to 'slave'.
If you have the 80-wire cable, you need to set the jumpers on both of the old drives.
Set both disk-drives to 'C(able)S(elect)'.
Is the new SATA drive just a "data" drive, or did you install Windows onto it?
Posted on May 27, 2011
  • ikkenom Jun 01, 2011
    Attach just ONE of the EIDE drives, and see if it is detected as "slave" or as "master".
    Disconnect that drive, and connect the other EIDE drive, and see if it is detected as "slave" or "master". Hopefully, you'll get one "slave" and one "master", when using an 80-pin IDE cable.
Intel Rapid Technology off line hard drive?
Open the computer and check cables. 0 is the 1st drive and usually the primary. Then login into BIOS and verify the drive is listed there. It must be.
Crashing may be a sign of hardware failure, but fix the HD problem 1st. Then run chkdsk c: /f/r C being the drive letter from the command prompt.
Apr 26, 2013 | Western Digital WD2500BEVT-22A23T0 - 250GB...
BIOS will not let me change boot sequence of hard drives. It lists both of them (one SATA and one IDE). Trying to recover info off IDE, primary OS is on SATA. How do I get BIOS to let me change sequence?
check the the jumper pins on the back of the HHD, SATA should be set to master & IDE to slave read the top of the HHD first coz some HHD's have master without slave presant.
boot up as normal then go into "computer" & get the data off the IDE drive.
Oct 20, 2010 | Intel D102GGC2 Motherboard
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
How do I set the jumpers on my Maxtor DiamondPlus 9 80 GB SATA /150 HHD drive as a second drive.
SATA drives are jumperless -- each drive has its own cable to the motherboard or controller -- so there's no setting on the drive to say "primary" or "secondary" as there was with IDE.
The connection on the controller or the motherboard will determine which drives are primary and which are secondary.
Jan 06, 2010 | Maxtor Hard Drive
Sata hard drive could not be detected during win xp installation in acer aspire M3600
It could only be a limited number of problems:
1. SATA drive is not connected to the primary port
2. SATA cable is faulty
3. SATA drive is faulty
The most common solution is to move the cable to the primary/first port
Jul 30, 2009 | Acer Computers & Internet
Adding old hard drive to new pc!
the seagate HHD (secondary drive) need to be on the same cable as the primary HHD. unless you haev SATA. then it is need to be connected to the second SATA connector on the mother board.
go to BIOS setup and make sure the BIOS know there are 2 HHD.
you should be good to go.
Mar 09, 2009 | Dell Dimension 5100C (D51CL1) PC Desktop
Installed more ram and now can't find the hard drive
Pull out the new RAM chips and install the old one or ones and see if it boots ok. I had this same problem. This can also be caused by no using matched sets of RAM chips. In my case I added one and used the factory one as well, caused the same issue as you have.
May 19, 2017 | Western Digital Caviar SE 80 GB Hard Drive
XP to vista and install sata drive
Yes vista will format & install on the new drive. Just make sure if there is an o/s on the old drive that you set up windows vista as a dual boot if you wish to keep using the o/s on the old drive. Hope this helps.
Dec 25, 2008 | MSI K8N Neo-FSR Motherboard
Trying to install wd 160gb sata drive on xp home sp2
try a newer xp version (sp3)
or custum build u;re xp, use nLite for it ...
Also in bios u can use the "ide mode" on the sata drive, if u have that option! (it wont afect u;re performance !)
Dec 11, 2008 | VIA JetWay PM9MS Socket 478 PM800 Micro...
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
