My hd television is zoomed in and I want to get it back to zoomed out. How do I fix this?
    Problem Solver:
  • 5 Answers
Question #1: do you use the remote which came with your tv or a remote for cable, satellite, etc that you use to Comtrol the TV? Question #2: what manufacturer of tv and who is your cable, satellite provider?
Posted on May 27, 2011
How do i fix a too wide picture on my sony kdl40ex500?
Why are you using 4:3 letterbox? It might be the default aspect ratio but widescreen tvs should be set to 16:9 aspect ratio.
Aug 22, 2014 | Sony KDL40EX500 40 in. HD-Ready TV
I just bought a new insignia LCD TV and the picture does not cover the entire screen. Instead of the 32 inch. diagnal I should, I have a 24 inch picture. Is there something I can do about it?
The "picture size" on the TV needs to be set correctly. You should have a "ZOOM" button on your remote. Press it a few times, cycling through the options... see if this fixes the problem.
Be advised, many (most) HD channels do not show HD content all the time. At the broadcasters discretion, they may choose to ADD the black bars to either side (and/or top an bottom) of the image. This is what the "ZOOM" button is actually for... to allow you to correct this, filling the screen with the image.
*Note: many cable box have a "FORMAT" or "HD ZOOM" button. When used in conjunction with the TVs zoom feature, you can end up having one device set correctly, while the other is not. The result is often a picture that is expanded far beyond the bounds of the displayable area of the screen. If you can not find a solution using the "ZOOM" button, pick the setting which shows the most image. Now adjust the cable box setting (FORMAT / HD ZOOM).
Mar 06, 2011 | Insignia Televison & Video
Lost my remote and tv is hung on zoom...anyway i can get off zoom without the remote?
Yes there is a way around zooming in and out without the television remote control. The cable box/satellite tv receiver also has an option to zoom in and out on it. BUT it usually only works when you have the hd box/receiver AND the television has to be on the right input in order to receive hd (component input or hdmi input). PLUS the cable box/satellite receiver should be set on the 1080i resolution (or 720p depending upon the resolution the television can accept). Then you can find the button on the remote that says #hd zoom (yes the # sign is on the button) or the button may be format or aspect.
Feb 08, 2011 | Philips 32PFL3504D 32 in. LCD TV
I have a 37inch protron flat panel.Problem is the picture is to big. when you watch a football game you cant evev see any scores on the bottem of the screen.How do I zoom it smaller?
You can zoom it smaller with the hd zoom # button on your set top box remote not the television remote. The button might be format or aspect if it is not hd zoom. But you do have to make sure the set top box is set to the correct resolution for this television (1080i for 1080i/1080p televisions and 720p for 720p televisions). You might also be on the incorrect input on the television so make sure you aren't.
There is also a wide button or view mode or etc. button on the television remote as well.
Nov 02, 2010 | Protron PLTV-3750 Television
HD TV screen is zoomed to far out. How do
Use the Picture, Zoom, or Aspect button on the TV remote to cycle through the available screen sizes. You may also be able to set screen size in a Setup-Picture (or Video) menu.
Jan 18, 2010 | Televison & Video
Sony KDL xXBR4
I just figured it out!! I have a comcast hd box and the remote has a small button on the bottom that says HD Zoom. Press that button and the display zooms several levels one of which is Normal. At least that solved my problem. Hope this works for you. Se easy it is stupid!!
Oct 19, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Apr 30, 2008 | Samsung HP-S5053 Television
Unexpected zoomed-in picture on my JVC PD 42X776
Depending on the cable provider there is a zoom function on the cable box remote , # for time warner.
Feb 27, 2008 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Samsung 1080p LCD TV stuck on zoom
I had the same problem. It's the default setting on your HD cable box. You have to go under the cable box's "settings" and switch it from "Zoom 1" to "Normal." I found the solution on Samsung's webpage. Can't tell you how much that was driving me nuts.
Jan 02, 2008 | Televison & Video
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
