Question about Altec Lansing 5100 Computer Speakers
Speakers for Altec Lansing 5100 system on and off
THe subwoofer and speakers of the 5100 connected to my Dell Desktop work on and off. I check ed all connections and cables and everything seems to be okay. Is the a fuse inside o something that can be caousing this interruption?
THanks
Hugo
  • 185 Answers
This is due to small mismatch on ur dell desktop with speakers, so remove it and try again
Posted on Aug 16, 2008
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
Nov 16, 2014 | Dell Harman/kardon Hk395 Computer Speakers...
How do i connect my 5.1 speakers to my desktop computer
Know Your Speaker SystemGenerally in systems all the cables from the speakers are connected to the subwoofer which comes with a set of wires to connect, that includes : a power cord to connect the system to the AC outlet, a power connector to feed the subwoofer and the subwoofer wires. Your system should come with at least three set of cables for connecting your speaker system to your PC. These cables are usually colored to help with the installation.imageview-thumb.jpg
Start ConnectingYou should connect the cables matching the colors on the jacks located on the subwoofer. After connecting all these cable, its time to connect the rest of the cables like power, subwoofer and speakers. This is very easy if you pay attention to the subwoofer connection then you’d be able to follow the polarity that is written on the connectors. In the end, all your cables would be connected perfectly.
The above pic shows you all the ports to connect the wires to with all the color coded mannerism.
Knowing Your ComputerAll computers have atleast three connectors
  • Line-In.
  • Line-out.
  • Mic.
Computers with six channel audio systems have two more connectors, i.e
  • rear out.
  • center/subwoofer out.
You’ll need to make sure if you have these extra connecters by checking the back side of your computer.
If your computer doesn’t have these two extra outputs: rear out and center/subwoofer out, it’s a disadvantage, you’d be able to connect your 5.1 anyway but you would require to use the line in and mic-in plugs as an alternative. Of course there is a really big disadvantage in using this configuration: you cannot use your microphone or line in inputs and your 5.1 speaker system at the same time. This is the reason that you should buy a motherboard with 5.1 system built in.
Configuration Of Computers With 5.1 Supporting Motherboards
  • Front cable: To Line out.
  • Rear cable: To the Rear-Out
  • Center/Subwoofer cable : To Center/Subwoofer Out.
Configuration Of Computers Without 5.1 Supporting Motherboards
  • Front cable: To Line-out.
  • Rear cable: To Line in.
  • Center/Subwoofer cable: To Mic-in.
Software ConfigurationAfter every single connection has been made, its time to setup audio configuration in operating system. Since we had Realtec drivers on our PC, Double clicking it opened up Speaker Configuration tab. In various options you should select 6 channel mode for 5.1 speaker output and check Only surround-kit if your PC has the separated rear and center/subwoofer outputs and leave it if you don’t.
Now everything is done, you are completely ready to enjoy surround sound experience and don’t forget to leave comments if you find this post useful.
Apr 14, 2010 | Computers & Internet
No sound on my pc
Go to Control Panel, Sounds and Audio Devices
Ensure that sound card is the default playback and default recording device.
Also, if this is a Dimension 5100, then there is a possibility that the system has a upgrade sound card installed in a PCI expansion slot (Below the video card)
If the system has an expansion card, (Soundblaster) then the integrated on-board audio should be disabled in the BIOS (If integrated is on and an expansion card is installed, you get a conflict and no sound) Normally, if the system has an expansion card, the ports are covered with a black plastic cover. If the BIOS defaults are ever reset, then onboard audio needs to be disabled again.
Mar 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
No sound opliplex GX620
Check the speaker cable connections.
Ensure that the subwoofer and the speakers are turned on
Adjust the Windows volume control
Disconnect headphones from the headphone connector
Test the electrical outlet
Enable digital mode
Eliminate possible interference
Run the speaker diagnostics
Reinstall Audio Driver
Check the device option setting
Run DELL 32 bit DIAGS
Mar 03, 2010 | Dell OptiPlex GX620 PC Desktop
There is no sound in the right channel of my Dell 5100 desktop running XP pro
check rear speaker connection to make sure plug is fully inserted in PC. if this doesnt work try using a different set of speakers. if still just mono then replace sound card.
Jun 09, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
No sound from sub woofer---just humming sound when turned up
Make Sure you have connected properly. If you purchase the speakers from DELL, Click here download the manuals.
Thanks, PREM
Mar 28, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 5100 - no power
It seems that your SMPS power supply may be having some fault...try to replace it...
Dec 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Subwoofer not working
check out is the adapter working or not an adapter is the one which is connected between the subwoofer and mains port which steps down the voltage if the adapter is not working ull not get the light just check it out if adapter is not working relplace the adapter and ull get the light and sound
Nov 12, 2007 | Dell WL6000 Computer Speakers
Altec Lansing 5100 Computer Speakers Logo
251 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
