I cancel the printing job in my computer, but the printer keeps printing garbage. I disconnected the printer from the computer and it stopped printing, but the minute I connect the computer it restarted to print the garbage.
Try restarting the print spooler.
Click the "Start" button, then click "Control Panel", then click "Administrative tools", Services, scroll down to print spooler, right click and select "Restart."
Posted on May 27, 2011
How to stop printing
While your question is not quite clear, I will provide a couple of suggestions. Usually when you press the cancel button, it pauses the printer and then you must use the arrow keys to select cancel job and then press the checkmark. Also check any computers to make sure that they do not have a job in their print queue. If the printer does not send back a job complete command, sometimes the computer will keep resending the job. Failing all else, restart your computer and your printer. Are the pages that are printing gibberish or is it the correct print job? If gibberish, you might have a corrupted print driver or the file you are printing might be corrupted.
Jul 15, 2014 | HP LaserJet P4014n Printer
How can I stop the printer,it keeps on printing
This is very little info to go on, but this is probably caused by a corrupted print job in your print queue. Power down and disconnect the printer. Go to the printer folder and double click on the printer icon. If you see a print job listed i the queue, make sure the title bar of the dialog box says "offline". If not, go to file, select use printer offline, and then right click on the print job and selet delete. If the job does not go away after a few tries, reboot the computer with the printer disconnected and try again after reboot if the job is still listed. Another way would be to try pressing the cancel button on the printer if you already haven't. More information would make it easier to give you more accurate info..
Sep 29, 2010 | Office Equipment & Supplies
The printer turns itself on autamaticcally and wont stop printing
You need to cancel all pending print jobs on the queue. If you see the printer's icon on your System Tray, lower right corner of your computer, right click it and choose Cancel Print Jobs. Or you can double click it so that it will show you the current printing job or those in queue. Select and delete them. If this does not cancel the pending print jobs, disconnect your printers power cord and shutdown the computer. After like 10 minutes, turn the printer and computer back again.
Dec 01, 2009 | Dell Office Equipment & Supplies
Printer will not stop printing
look at bottem right there is a little printer symbol right click on it then cancel all jobs
Sep 20, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
When I start the printer it begins printing a site, that I did,nt ask for, and it keeps printng the same site until there is no more paper
1.) turn off the printer., disconnect the connection between printer and computer ( usb cable )
2.) for win ( xp, vista ) cancel pending doc's in the print and fax
3.) reconnect the cable back to your computer power on the printer and try t print.
4.) for mac systems cancel stopped jobs., delete and re add printer in the printer list and then do step ( 3 )
Apr 03, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Cancel Job
The only other way you can stop it is to stop the print job from the computer. Press the start button. Press the control panel. Select printers. pick the icon of the printer and double click it. Highlight the print job and press the delete button.
That will canel it.
Aug 25, 2008 | Zebra 105Se Thermal Printer
Cancel already sent job
turn off the printer, and disconnect from computer..turn it back on, and clear all jobs from front panel controls
Mar 20, 2008 | Brother HL-2040 Laser Printer
How to interrupt a printing job and cancel it
Hi, I hope I can help.
Your printer has some of the pages stored in memory, and your computer also has some of the pages stored in the memory (spooler) on your computer.
If you turn off the printer, the computer thinks the printer went off-line and it waits for it to come back on, and then just keep churning off pages. OR.... Something will get messed up and 100's of garbage pages will start churning out.
The deal is to clean out the memory on the printer, AND clean out the spooler on the computer.
Simplest way (hopefully) is to turn off both units. That may solve it. However, sometimes the spooler on the computer will keep trying to print. Down in the lower right hand corner of your screen should be a picture of a printer. Double click that and you'll see the print job. You should be able to select the print job, hit delete, and clear it from the spooler.
Hope this works.
Feb 28, 2008 | HP LaserJet 1020 Printer
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
