Question about ASUS M2N68-AM SE2 Motherboard
M2n68 am plus reboots every second with x4 540 amd athlon 2 what could be happening i had a duel core processor then upgraded but my duel core processor was knocked off the desk by my stupid mother pins are bent now stuck with crappy laptop specs Motherboard - m2n68 am plus ram - kingston 4gb (2x2gb) ddr 2 processor - athlon 2 x4 640 what could be causing this
  • ASUS Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap hope this helps
Posted on May 27, 2011
Hi, I'm running an AMD Phenom X4 9500 off of a Asus M2N68-LA (Narra3) board. What, if any, processor could I upgrade to on this board in order to get better speed? TIA Peter
Narra3 supports X2 up to 5600+ up to 89 watt Socket AM2 Processor (currently AMD Athlon™ X2 6000+) AND X4 up to 9600+ up to 95 watt Socket AM2+ Processor (currently AMD Phenom™ X4 9600+)
Sep 23, 2011 | Computers & Internet
M2N68-AM PLUS does not support cpu AMD Phenom 9750
No it does not. although it says it supports sockets AM2, AM2+, and AM3 and the Phenom 9750 is an AM2+, the Phenom 9750 has a wattage requirement of 125 watts. This motherboard ONLY supports CPU's up to 95watts! You would either need to get another motherboard or another CPU (or both and make a second computer).
Side note: also keep in mind that if using this motherboard with an AM2+ CPU, it will not be able to handle 1066MHZ memory (or higher) in dual channel mode, in order to get this speed you will either have to take out the second dimm or run both dimms at 800MHZ.
Hope this helps!! (and if it does, please rate or leave comment. It will be much appreciated!!)
Feb 12, 2011 | ASUS M2N68AM PLUS Motherboard AMD Athlon...
I am using amd sempron LE-1100 i want to upgrade to a gaming pc so that i can play the sims3. so if i like to upgrade to amd athlon x2 how to know my socket type. please help
Your socket is AM2. You can put any AMD processor that has AM2. If the processor is AM3 just upgrade the bios of your motherboard and it should work. If you need further assistance, just leave a comment. Cheers
May 24, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Want to upgrade to amd athlon 2
Hi........Socket 939 is an outdated processor and not compatible with Athlon 2. You may find a 939 dual core on ebay, but suggest you save up for an AM3 mobo. Hank
May 10, 2010 | ASUS A8N-E Motherboard
No beep, no display in new asus m2n68-am se2 motherboard
Try booting the system with a bootable and well memory stick and probably check the power switch if it send any signal to the board while pressing it.
May 07, 2010 | ASUS M2N68-AM SE2 MicroATX Motherboard &...
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
Compatibility
A8V-MXs are built for AMD processors. You will need a board made for Intel processors if you want to purchase the above processor. If you want to stick with Intel and Asus check out the P5 series of boards. If not, buy an AMD chip...I've had AMD in almost every one of my computers, laptops and desktops.
Good luck.
Dec 20, 2007 | ASUS A8V-MX Motherboard
ASUS M2N68-AM SE2 Motherboard Logo
73 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
