Question about Kenmore 74121 Air Conditioner
Can you recharge this type of air conditioner? It is now 5 years old and doesn't feel as cool. Thanks
    Genius:
  • Kenmore Master
  • 1,033 Answers
Hello, yes the air conditioner can be recharged however you will need to add a piercing valve to the low side of the system in order to add refrigerant. Here is a link to a store thta carries piercing valvs http://www.apwagner.com/index.php?main_page=index&cPath=5_227
Posted on May 27, 2011
Hi i have Fujitronic FA-1300 Dual Hose 13000 BTU Portable Air Conditioner the air comes out it not cold does it need gas?
Before assuming it needs to be recharged with refrigerant gas, check the following. As all of these things can affect the cooling,
1. Remove and clean the air intake filter.
2. Check exhaust hoses for obstructions.
3, Exhaust hoses may have to much downward droop. Which doesn't allow the air to exhaust as it
should.
4. check for holes or leaks in the exhaust hoses. Repair or replace the hoses as needed.
5. Check the temperature setting on the controls, as it may be set to high.
If none of the above solves the problem, it may need to be recharged with refrigerant gas. hich is best left to the pros.
I hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Heating & Cooling
My Fedders AC in my 2003 Roadtrek runs but doesn't blow cold air. Can't find valve in order to recharge it. Can you tell me where it is?
Window Air Conditioner are sealed at the factory,
no service valves & you can not buy R22 without
a licence
If you had to add refrigerant,common sense would
say you have a leak
Seldom repair that type of unit
It can be repaired sometimes, but usually they are
20 years old & you get a new one
Jul 16, 2011 | Fedders Q Chassis AEQ08F2E Air Conditioner
I have a portable air conditioner - Hotpoint MAC 130 and it blows cold air only rather than cooling down like it used to be. I bought it 5 years old and haven't been using them very often. It still...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Heating & Cooling
My air conditioner is 8 years old and no longer cooling the air that well. I always clean the filter. Is there a way to recharge or add freon to the unit?
Yes, it can be recharged. But, due to equipment that is required to do this, it's best left to the pros. Especially, since there are EPA requirements that have to be met, when evacuating the system, prior to recharging it.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Maytag M6Q10F2A Air Conditioner
Unit ices up and quits cooling
There are a couple of things that contribute to the problem you're experiencing:
1. A dirty or clogged air intake filter. Turn unit OFF, remove and clean the filter. If filter is washable
be sure filter is thoroughly dry, before reinstaling it.
2. Cooling fins are dirty. Turn unit OFF, remove the outer shell of the AC unit, if necessary and
clean the fins with an old toothbrush and a vacuum cleaner.
3. Humidity level in your area is extremely high. This is Mother Nature's problem and is not readily
solvable.
4. Defrost sensor is not functioning properly. Replace sensor.
5.. Low refrigerant gas in the AC's compressor. Have compressor recharged.
Hope this helps you trouble shoot and solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Friedrich TwinTemp EL24J35A Air...
Does not cool room.
Goldstar WG5000 air conditioners use an R22 refrigerant. A charge kit containing the gauges needed to properly fill the unit, and the refrigerant tank/cartridge can be purchased to fill the air conditioner.
Jun 03, 2010 | Goldstar WG5000 Air Conditioner
Danby DAC5020 Air Conditioner fan works but not compressor
It could be as simple as being low on refrigerant. Depends on how expensive the unit is if its worth recharging and how big the unit is. Some small units will need to have a recharge point fitted which cost more of course.
Jul 02, 2009 | Danby DAC5020 Air Conditioner
Older roof mount RV Colman Air Conditioner on a 1989 Motorhome(class C)
It depends how old it is most can be regased but about 15 or so years ago they changed refrigerant gases because the old one was killing the ozone if not that old you should have no problems with regasing it just make sure they check for gas leaks first which is a small amount of dye put in the gas so you can see the leak. Hope this helps
Jul 22, 2008 | Coleman Mach III Air Conditioner
Kenmore 74121 Air Conditioner Logo
221 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
