After a technician changed the key board of my lap top he said is a problem now with the power button and the machine cant start, so he said he need a replace a power button because is something waste o broke, it that is true o he is taking advantage.. thanks
    Sergeant:
  • 207 Answers
Most laptops power button has nothing to do or connection with its keyboard it is not on the same module. it could be that a technician may have accidentally break the power button when he is removing the keyboard panel of your laptop
Posted on May 27, 2011
IS MY DELL LAP TOP BE FIXED IF SOMEONE POORED 1/2 GAL CLOROX BLUCH ON THE KEY BOARD?
I am sure half of gallon of bleach is alot of fluid.
You will have to open up the laptop and inspect it. I advised to take it to a trained technician.
Jun 07, 2014 | Dell Inspiron Computers & Internet
My lap top its not responding to power button and i cant start my lap top
Unplug the battery and the power cord. Hold down the power button for 30 seconds. Plug back in the battery and power cord. Try powering on the laptop. If it powers on you are good to go. If not try contacting Lenovo support.
May 31, 2014 | Lenovo 3000 G530 Notebook
How to unlock bios of toshiba portege m500
two options
1. look on the mother board for a small round battery about the size of a nickle, remove it, start pc, after start up shut down, replace battery, start up again... or remove battery, let sit for about 30min, replace battery start pc.
2. look for a small red or yellow toggle switch or button on the mother board, (should say "reset bios") push button, restart pc.
i assume this is a lap top so there will be some disassembly of the unit, not to extreme though, usualy the battery and the switch/button are next to one another and located toward the front of the mother board, and if in lap tops the battery or batteries are in a plastic covering wired to the mother board with a small connector, just unplug connector if you cant find the reset button.
hope that helps
Mar 23, 2011 | Toshiba Computers & Internet
Acer 3680 No display when computer is powered up. Tried the brightness buttons, did the Function F5 key combo to make sure it wasn't set to external display, it wasn't in sleep mode. Are there any other...
take reboot off f2 push f2 3 or 4 times if screen is black when lap top start push f2 then use arrow keys on key board then you will change boot log to f12 now pushf10 to save settings and enter exsept now when it starts up again push f12 now its going to ask you 3 questions go to 2nd question then push enter.
Feb 15, 2011 | Acer Aspire 3680 Laptop
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
My acer lap top key board is doesn't work
Try to turn off the acer laptop, remove the cables and battery . Press & Hold the power button. Then replug cables and battery. Turn on pc and if symptopm persist, consult acer tech support at 1-800-816-2237
Dec 14, 2009 | Computers & Internet
Lap top can not start even button lights
do static discharge
disconnect battery and all peripherals. disconnect from mains. press power button and hold for 30 sec.
Connect to mains and try to turn on again
If it will not start - mainboard needs replacement
thanx
Sep 14, 2009 | Toshiba Satellite M40-S417TD Notebook
Monitor goes to sleeep on lap top
Hello, you can try this... Connect your laptop with an desktop monitor throughVGA cable.... then Click on start>> goto control panel>> Double click on Power Option>> Under Power Scheme it should be Poratble /Laptop >> Select Never under System Standbye, Trun off Monitor and Turn off Hard Disk.
Thank you for contacting Fixya support, please rate if that helps!!
Sep 06, 2009 | Relisys RLT1720 17" LCD Monitor
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
How to turn on wireless on Acer Aspire 4520 laptop
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Sep 04, 2008 | Computers & Internet
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
