Question about Logitech ClearChat Pro USB Headset
My headset was working fine but all of a sudden the volume will not stay at the level I turn it up to. It keeps rolling back down to barely any sound coming through. I try to use the button on headset but nothing happens. Any ideas why this is happening?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to solve your problem. Your Logitech ClearChat Pro USB Headset's volume will not stay at the level you turn it up to, and as a result it keeps rolling back down to a lower sound quality. Your volume control button doesn't solve the problem neither. Well, when a problem occurs, you should first troubleshoot where it's coming from. We will use a method called "Process of elimination". Your headset's volume has two controls: one control is on the headset itself, and the other control is located in the sound settings of the device you have your headset plugged into. With this thought in mind, lets go up to the problem explanation above. You said that the volume control attached to the headset didn't make a difference, this means the you can eliminate the hypothesis that it's the volume control causing this. The problem is coming from the earphone portion of the headset. Either a mute setting has been activated, volume is turned down real low or your headset is not the default device to receive sound input. The first part of the investigation is done; now, to get further into the investigation, you will need to connect your headset to your computer. This is where troubleshooting and solving the problem meet. Step-by-Step, I am going to explain to you how to get audio presentations into your headset. This device works with two Windows Operating Systems (Vista and XP) and one Mac Operating System (OS X). If your computer's operating system is Windows, open your Control Panel. Under the Hardware & Sound link, click Manage Audio Devices (for Vista users), and the Sound & Audio Devices link (for XP users). If your coumputer's operating system is Mac OS X, open your System Preferences and click the Sound link. In Windows Vista, click the name of your device, then click Set Default. Click the Properties button and increase the volume slider or unmute the volume if needed. If applicable, click the Apply button, then click OK. If the Apply button is void, just click OK. Click the Recording tab and perform the same procedures as you did before, only difference is that this will make your headset microphone the default recording device. In Windows XP, click the Audio tab and set the headset as the Sound Playback and Recording device. Increase the volume or unmute it if needed. When finished, click the Voice tab and perform the same procedures as you did before. In Mac OS X, click the Input tab and select the headset as the input device. If you still can barely hear anything, increase the volume slider. When finished, click the Output tab and repeat the same steps as before; only thing, you will be making this the sound output device, meaning the sound of your voice will be outputed from the microphone. Increase the volume slider if needed. You should be able to receive sound in and out of your headphones now. If we succeded, through this experience we have: troubleshooted where the problem was coming from, found a way to solve it and fixed the problem! Thank you for choosing FixYa as your one-stop solution spot for problems, questions, concerns and requests. Visit our website again the next time you need assistance with something. Thank you and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
Posted on May 28, 2011
When i first turn on tv sound is fine . then it will drop down in volume badly .
Many newer types of TVs have what's called "Volume Leveling", which means the TV automatically lowers the volume if a sudden increase in the broadcast signal volume is detected. Check to see If "Volume Leveling" is present on your TV and currently turned "on". Refer to your owners manual for this. It should be in the Audio section in the menu on your TV. Turn the "Volume Leveling" to the "off" position to disable "Volume Leveling".
Jan 23, 2016 | Televison & Video
The sound is distant?
Plug the USB connector into an available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
May 04, 2012 | Dynex Radio Communications
Can barely hear on full volume? Plantronics 232
1. Stay away from ambient noises 2. Press the up volume for 3 seconds. 3. Make sure it's in your ear all the way.
Jul 15, 2010 | Plantronics Explorer 220 Bluetooth Headset...
There is an Echo @ the other end when I am talikng with them. It sounds fine @ my end but always a problem At the recieving end????
I just figured this out for mine - unfortunately it's a little bit of a bummer -
Experiment with your volume levels. Get a guinea pig/friend to listen for the echo while they talk - start with your listening volume all the way down while they talk, and gradually turn the volume up, until they hear an echo. Knock it back down one more notch and you should be good.
Mar 03, 2010 | Motorola Mobility H390 Bluetooth Headset
For Sansa E260 MP3,can't get the volume up. Battery, headset fine
This link will show you how to take it apart. From there I suggest just try and clean it....Hope this works
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
Interferance with sound
Normal 0 If the people you are talking to have speakers they hear you and you will get feed back of your voice. Have them turn down the speaker level or better yet use a headset and this will no longer be a problem.
Hope this helps. Bud
Mar 18, 2009 | Microsoft LifeCam VX-1000 Webcam
I can barely be heard.
May not be your headset as the problem. Check you pc for mic level or plug another mic into it. If you have found this helpful or fixya, please post as such. For more help please go live
Jan 13, 2009 | Logitech ClearChat Style Headset Headset
Audio fade
if there is no problem with the surround sound, you have a problem with the volume regulation circuit or with the main amp of this TV set, But to say the least is you have a backup to fix your problem, with the sound system, you said it works fine. this could run ya about 250 to 400 to repair. Good luck.
Mar 29, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Logitech ClearChat Pro USB Headset Logo
412 people viewed this question
Top Logitech Radio Communications Experts
Charles A Stimeling
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
